New sealed sub box
New sealed sub box
Hey guys, I was busy today constructing my first ever DIY sub box. Total cost was about $38!!! It's 1.34 ft^3. I'm putting an Image dynamics 12" DVC 4ohm sub in with a Soundstream Rubicon 1.400 amp. The box took me about 4 hours to finish but I think the time was well worth the savings! I used 3/4" MDF. It measures 13.5" tall x 23" wide x 8" top depth x 14" bottom depth. I angled the back to make it so it rests flush against my 05 EX SE seats for maximum trunk space. I contemplated making braces for it, but the design feels very sturdy so I decided against it. I'm going to drill a small hole to insert speaker wires, then seal w/ caulk. Let me know what you think.
Re: New sealed sub box
Looks pretty good
for the speaker wires, instead of drilling a hole and sealing it with caulk, you can put a terminal plate, like these ones:
http://www.radioshack.com/product/in...ductId=2102834
or
http://www.radioshack.com/product/in...ductId=2103794
I have the first one on my box, and I terminated my speaker wires from my amp to banana plugs, making it all plug and play. I have mine sealed in place with silicone.
Thats another option to give you a little more of a professional look and in the case you have to take the box out, you can just disconnect the wires from the box and drag it out.
or
Yeah, i like that idea of being able to take it out if needed. Of course once I get some L brackets in there, it will be a bit more cumbersome but still doable. I've heard mixed reviews about those plates though...as far as leaking, so I'm a little concerned.
Walmart has a 12" box at about that price, probably could have saved four hours. But, it looks good nice job, I agree with using the terminal plate makes things very simple if you ever need to remove your sub to put something in the trunk.
is the box properly sized for the sub woofer your going to be using ???
robjcivic
Mar 12, 2017 12:10 PM
Sep 27, 2015 11:33 AM
hatch90
Sep 3, 2015 08:45 AM
h4ldol
19
Jul 28, 2015 01:01 AM
