buring alts.
Old Apr 11, 2010
instalher's Avatar
instalher is an unknown quantity at this point
buring alts.
iam now on my 4th alt. in my 03 civic lx 4dr.. i have noticed that the alt is way to friken close to the exhust manifold.. and when i go on a road trip, like over 1000miles, i usually return with a burn out alt... is there something i can wrap around the manifold to shield the alt from the heat? or i am thinking of running a pipe from the bumper up to the alt and this will blow cold air across it.. just a thought.
Old Apr 12, 2010
electric130's Avatar
Re: buring alts.
the exhaust manifold should have a heat shield on it already. if it doesn't then you can get insulating manifold wrap from a parts store.
Old Apr 12, 2010
Awjvail's Avatar
Awjvail is an unknown quantity at this point
Re: buring alts.
Do you have any aftermarket audio? Huge subs/amps etc? Those things can burn through alternators like nobody's business.
Old Apr 12, 2010
Re: buring alts.
www.jet-hot.com works wonders.
Old Apr 12, 2010
HLC's Avatar
HLC
HLC is an unknown quantity at this point
Re: buring alts.
the exhaust manifold wouldn't cause the alternator to melt. i don't have a heat shield on my mani and i've never even had to change the alternator.
Old Apr 12, 2010
Re: buring alts.
improper ventilation can cause worn bearings, one of the biggest causes of alternator failure besides charging system issues or worn belts.
Old Apr 12, 2010
HLC's Avatar
HLC
Re: buring alts.
having too much tension in the belt could also wear the bearings out.
Old Apr 13, 2010
onlycodered's Avatar
onlycodered is an unknown quantity at this point
Re: buring alts.
This. I just had my alternator replaced due to shot bearings because whoever serviced my car from the previous owner tightened the belts way too much. I've got to get a new AC compressor as well because the bearings are shot on that as well.
Kingsofone
Apr 3, 2013 12:00 AM
marcus1991
Sep 18, 2012 02:23 PM
kames
Feb 13, 2011 03:41 PM
usafstud
Jan 1, 2008 11:23 AM
