reverse ding!
Old Mar 21, 2010
dxdude's Avatar
dxdude is an unknown quantity at this point
reverse ding!
I just switched to an asian guage cluster from an 01 es civic, everything works properly, however this cluster produces an annoying dinging sound when the car is in reverse! Ive tried removing the reverse bulb in the cluster but that didnt work. anyone know how I can stop the dinging? lol thanks
Old Mar 22, 2010
dxdude's Avatar
Re: reverse ding!
bump?
Old Mar 23, 2010
CraigW's Avatar
Re: reverse ding!
I would say you will have to live with it, most likely it is using the seat belt/key in ignition/headlights on warning buzzer which is part of the cluster.
Old Mar 23, 2010
dxdude's Avatar
Re: reverse ding!
thanks for the response I figured it was using the same speaker thats in the cluster, but I would rather have no sounds at all then other sounds plus this one. In other words, if there is one specific wire for sounds somewhere i can clip or something to that extent I would go without any sounds. thanks!
Old Mar 23, 2010
CraigW's Avatar
Re: reverse ding!
The wiring shows a "drive circuit" and a "beeper" it shows 2 single connections made to the beeper from the drive circuit. If the beeper has actual leads you could cut one of those to silence it. You may be able to cover it and quiet the noise as well. Can't be much more help as I have never had one apart...only guessing.
Old Mar 23, 2010
dxdude's Avatar
Re: reverse ding!
thanks Craig, is the wiring youre talking about for the harness? or inside the cluster
Old Mar 23, 2010
CraigW's Avatar
Re: reverse ding!
I'm quite certain it is all contained inside the cluster,you may be able to located the buzzer and see if wires are attached or it may be soldered into a board ??
Old Mar 23, 2010
Awjvail's Avatar
Awjvail is an unknown quantity at this point
Re: reverse ding!
Any photos of the cluster?? I didn't know the JDM Civics had different clusters.
Old Mar 24, 2010
dxdude's Avatar
Re: reverse ding!
It just looks the same as any canadian lx/ex cluster, the reverse dinging is the only difference from what I can tell. I needed one in metric kph so I bought this one instead of the many mph ones on ebay.
Mad Dog Tannen
Oct 19, 2016 08:12 PM
ThatGuy913
Sep 28, 2015 05:35 PM
carid
Sep 28, 2015 10:13 AM
Yang559
Transmission
Sep 21, 2015 01:41 PM
BBrosario
Sep 17, 2015 07:51 PM
