Fuses? :/
Old Dec 29, 2009
Ginfu's Avatar
Ginfu is an unknown quantity at this point
Fuses? :/
Sup people...just installed a new hu and my locks and lights dont work when the ignition is in the first position...the hu doesn't come on at all. It's brand new. Did some research and I'm thinkin blown fuse(s). What do you think :/
Old Dec 29, 2009
Re: Fuses? :/
did you connect the wires properly? you cannot just match up the colors, alot of times they are different and you need to use the wire diagrams from the harness and radio. check all your fuses too.
Old Dec 29, 2009
Ginfu's Avatar
Re: Fuses? :/
yessur they're matched properly...so what's the quickest way to check the fuses?
Old Dec 30, 2009
Re: Fuses? :/
get a flashlight and look at each fuse, make sure the metal is not broken in the middle. there is a fusebox under the dash (above the brake pedal) and also next to the battery under the hood.
Old Dec 30, 2009
CraigW's Avatar
Re: Fuses? :/
"back up" fuse in under hood box.
Old Dec 30, 2009
BlueEM2's Avatar
Whachya lookin at?
Re: Fuses? :/
Did you hook up the illuminator/dimmer wire?? That would do it.
Old Dec 30, 2009
BlueEM2's Avatar
Whachya lookin at?
Re: Fuses? :/
Old Dec 30, 2009
CraigW's Avatar
Re: Fuses? :/
Can't even be sure if it is a 7th gen or not.
The back up fuse pertains to items that require constant power.
When you tie in wrong for the illumination it opens the "small lights" fuse.
Old Dec 30, 2009
Ginfu's Avatar
Re: Fuses? :/
I fixed it today...went and checked out the box and it was the back up fuse...what's that one used for anyway and how'd i pop it?
Old Dec 31, 2009
CraigW's Avatar
Re: Fuses? :/
"The back up fuse pertains to items that require constant power"
It is used for your radios clock and station memory and also for the constant power for the keyless reciever as well as other things.
Old Jan 5, 2010
Ginfu's Avatar
Re: Fuses? :/
oh ok cool...thanks that's good to know cause my keyless remote was actin a fool too lol
Old Jan 8, 2010
04 Honda Civic's Avatar
Re: Fuses? :/
Next time you do ANY electrical work on your car disconnect the Negative (-) battery terminal so this **** doesnt happen, your lucky thats all you blew.
Old Jan 8, 2010
BlueEM2's Avatar
Whachya lookin at?
Re: Fuses? :/
^ I second that
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
h4ldol
Apr 24, 2017 08:16 PM
Klame9420
Sep 18, 2015 12:37 PM
Mc7602
Sep 17, 2015 02:01 PM
h4ldol
Sep 17, 2015 01:25 PM
