Cruise Control Disengages when headlights are turned on
Old Dec 17, 2009
masterguns's Avatar
masterguns is an unknown quantity at this point
Yes, apparently a few people have had this problem. I've looked around and found a few threads on the issue, but no solutions. If anyone knows what the problem is or how to diagnose it, please let me know. I just drove 10 hours round trip to and from New Orleans with no cruise!!!
Old Dec 17, 2009
Re: Cruise Control Disengages when headlights are turned on
are the fuses okay? sounds like some sort of reverse feedback problem that is affecting the brake/cruise switch. may try putting a blocking diode on the power wire of the switch.
Old Dec 18, 2009
masterguns's Avatar
Which fuses control the CC? I just looked and don't see any listed 'cruise control' under the dash or under the hood? I'd imagine they're fine, since the CC works fine with the headlights off.
Old Dec 18, 2009
EK9_XCVI's Avatar
EK9_XCVI is an unknown quantity at this point
I have a testing procedure for 96-00. Don't know what year you have. My schematic also shows fuse 14.
Old Dec 18, 2009
for a 7thgen, since you posted in 7thgen forum, check number 10 and 4 fuses under the dash, and number 7 in the engine bay fuse box. also check to make sure the horn works and the tach. if the fuses are okay, it might be a bad ground.
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
cukaracha
May 16, 2015 02:11 PM
honkeydonkey
Electrical
Apr 26, 2015 08:27 PM
shaejb15
Apr 26, 2015 07:44 PM
Civic316
Electronics
Dec 10, 2001 12:03 PM
