Headlight problem
Old Dec 11, 2009
PolishNProud's Avatar
PolishNProud is an unknown quantity at this point
Headlight problem
This morning I saw that one of my headlights doesn't work ... When I turn the light switch on ... only one of them lights up, but when i switch them to high beam, both work perfectly fine.
Do i have to replace the bulb ?
Old Dec 11, 2009
BlueEM2's Avatar
Whachya lookin at?
Re: Headlight problem
Your low and high beam use different bulbs. Yes you have to replace a bulb, just make sure its the low beam bulb.
Old Dec 11, 2009
if you have 01-03, it uses the same h4 bulb, two different filaments inside. 04-05 uses different bulbs.
Old Dec 12, 2009
BlueEM2's Avatar
Whachya lookin at?
they are different??? hmm... who'd a thunk it
Old Dec 12, 2009
it's a 01 EX sedan ...
Old Dec 12, 2009
electric130's Avatar
then yes, you have 2 filaments inside one bulb. the high beam may work but the low beam can be blown. change the bulb.
Old Dec 12, 2009
Cleft_Asunder's Avatar
Cleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of lightCleft_Asunder is a glorious beacon of light
Change both bulbs, not one bulb. And go OEM, worth every penny. A friend of mine who used to have a 05 Subaru legacy bought sylvania silverstars 3 times in a row, and each time they went out within 2 months.
Old Dec 12, 2009
yeah stick with clear bulbs. 01-03 uses H4 size. i have the philips ecovision, they are clear and use 1 amp less than oem bulb, are 10% brighter, and last 1,000 hrs (2x more than oem).
Old Dec 12, 2009
Silverstars absolutely SUCK!!!!!!! listen to gear on halogens. since he can't make up his mind on HID's, he's definitely the expert on halogens.
Old Dec 13, 2009
Could I buy them at walmart or anywhere ? Or do I have to order them online ?
And should I replace both headlights ?
Old Dec 13, 2009
Personality's Avatar
Personality is an unknown quantity at this point
Always replace bulbs as a set, you don't want two different bulbs, and you don't want to have to replace one a little down the road because you only replaced the burnt out one.
Old Dec 13, 2009
^^^exactly
Old Dec 13, 2009
Ckutch02EX's Avatar
Ckutch02EX is an unknown quantity at this point
I like my Sylvania's. I keep my headlights on all the time even during the day and have had no issues for six months.
Old Dec 13, 2009
walmart has a pair of GE H4 for $12.
Old Dec 13, 2009
and i bet they are brighter than $40 silverstars!
Old Dec 13, 2009
well prolly the same brightness. silverstars use an overdriven filament otherwise the blue coating would rob too much light and put the output lumens below the legal minimum. maybe thats why their average lifespan is 50 hrs.
Old Dec 14, 2009
Got them changed, they were like $14 at walmart ...
Now my question ... what bulb would be the brightest and non-yellow looking.
Old Dec 14, 2009
phillips xps
Old Dec 14, 2009
yeah the philips xp is a clear bulb but is currently the brightest and much whiter than stock. they are almost $40 from www.powerbulbs.com but last as long as a regular bulb.
stryder12
Jun 30, 2015 08:33 PM
carid
Jun 5, 2015 11:51 PM
terry_tr6
HIDs and Retrofitting
May 16, 2015 08:37 AM
intensity
May 12, 2015 10:43 PM
shaejb15
Apr 26, 2015 07:44 PM
