Headlight housing replacement
Old Dec 8, 2009
redrazr's Avatar
redrazr is an unknown quantity at this point
My old housing is really blurry from inside, So I am gonna buy a new one and replace it myself. Any advice what i should be cautious about?
Step by step procedure would be very helpful.
I got a 2001 civic coupe EX.
Old Dec 8, 2009
Re: Headlight housing replacement
there is a diy here about how to clear headlights and it goes step by step. all you really do is remove the bumper, its held on with a bunch of clips and screws on the bottom and sides, and some under the hood where the radiator cover is, then it just pulls off. the headlights just have 4 bolts to remove.
Old Dec 8, 2009
sl33pyriceboi's Avatar
heres a tip if u do decide to remove the bumper.
gearbox mentioned those "clips", i would spray some sort of "bolt loosener" spray on them (like PB blaster, or even WD40) to loosen the dirt and crap build up IN them.
you can avoid breaking the clips that way.
Old Dec 8, 2009
Old Dec 9, 2009
prolly better to replace those clips anyway. alot of times they are too stretched out to work again without being loose. and they sell them in bulk on ebay for much cheaper than oem.
Old Dec 9, 2009
electric130's Avatar
i'd buy some extra off ebay. chances are a couple of the are scraped up under the car anyway. unless the car's never scraped a curb.
Poopies
Apr 20, 2017 11:36 PM
intensity
May 12, 2015 10:43 PM
thesushiboy
Apr 12, 2015 02:54 AM
Erichyung
Jan 2, 2002 05:43 AM
SWEETRIDE
Nov 27, 2001 05:52 PM
