Hella headlight bulbs?
Old Sep 6, 2009
hondaguy2582's Avatar
hondaguy2582 is an unknown quantity at this point
Been reading that Sylvania isn't all its cracked up to be, and hear Hella to be the better brand of the two. Any of you guys use the h4s in your civic?
Old Sep 6, 2009
Re: Hella headlight bulbs?
just your typical blue coated bulb, nothing special. i would stick with the philips XP series H4 bulb, which is the brightest bulb on the market that is street legal. much whiter than stock too and still 55w. its a clear bulb with thin blue ring at the top and alot of other enhancements. almost looks like hid on a dark road. www.powerbulbs.com
OEM
philips XP
Old Sep 6, 2009
Thanks. Putting them in the cart as we speak!!
Old Sep 6, 2009
d0ughbOy81's Avatar
d0ughbOy81 is an unknown quantity at this point
yea hella sucks i had them they were only blue for a week
Old Mar 2, 2010
eLChiCho25's Avatar
eLChiCho25 is an unknown quantity at this point
OK Maybe IM missing something ..but what makes Philips XP so special again? I just dropped about $50 on a pair.. I left 1 reg 9006 on the left and the XP on the right to see the difference....and notice VERY little difference with the reg 9006 ones I had already.. and they have a yellow glow rather than Bright White.. I hope they last as long..
Old Mar 2, 2010
xp has an optimized filament position and coiling, the capsule is smaller so the pressure and temp runs hotter, and there are a few other things. basically better in every way. do you have any pics? the H4 was a huge difference for me, even when i upgraded from the already good +50 VP bulbs to the XP. maybe the 9006 isnt as efficient.
Old Mar 3, 2010
civicpapi's Avatar
civicpapi is an unknown quantity at this point
Gear the second pic looks brighter lol.
9006 is a tiny low beam bulb, so maybe less of a real difference.
H4's are low and highs, so that is where I bet the real difference can be seen?
Old Mar 3, 2010
well the lo beam h4 and lo beam 9006 filaments are both 1000 lumens. the h4 hi beam shouldnt matter since its not used unless hi beams are switched on (and the lo beam turns off then). oem h4 bulbs are almost useless compared to the xp. only other thing i can think of is the 04-05 civics already have a better reflector design which the xp did not improve on as much.
cferry7
Oct 18, 2015 06:32 PM
rnaodm
Sep 21, 2015 12:42 PM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
