MORE HELP ON YOUR OWN CUSTOM TRUNK, A DIY
Old Apr 12, 2002
2k2civicballer's Avatar
2k2civicballer is an unknown quantity at this point
I posted a DIY a longggggg time ago. But ive been getting Emails, etc etc on how i did it.
try this link
original post
You need to caulk all the inside edges after putting them together. For your floorboard, take the piece of cardboard that is your floorbaord right now, and trace it onto MDF. Then you need to construct a box that the subs will "sit in". the dimensions of each piece of the box are avaialable at that site above
To insulate, I use cotton clothing stuffer avaialable at your local craft store or material/sewing store. I also put it under the box, so that no piece of wood touches metal, to reduce any rattling or moving/shifting of the box.
Youll need one sheet of MDF, available at Lowe's. I suggest 3/4in, but you could go with 1/2inch. It depends how sturdy, and how tight you want your bass. Its about 20-25 bucks for a huuuuuge sheet. Just get the good stuff the first time.
To insulate the edges, you can use standard bath caulk, or kitchen and bath silicone. You want this to be AIRTIGHT, so that each sub hits on their own.
I used 3/4in wood screws to put it together.
The SQ will be very high, if you take your time. Also, go to crutchfield.com, find the subs you have, and check what they recommend the air space be. You can adjust and fine tune the amount of FREE AIR in side each section, to best fit your subs.
Hope this information was useful!
EDIT: Today i was asked what to do if you have 15's, and they are a lot "deeper" and wont fit in a 12" sub setup. Well its easy. The "sides" of the box that subs "sit in" need to be raised, or the height needs to be ^^. so i would suggest finding out the EXACT top mount depth of your sub, then leave about 1.5-2 inches of free space between the magnet and the bottom of the box. Also, you might need to make the "front" and "back" of the box longer, to fit tighter in the part where your Tire used to be. Obviously because 15's are wider than 12's. I hope this helped, just remember...TAKE YOUR TIME!
Cheers
Branden
Any other questions ? Mail me at brandenwym44@yahoo.com, or civicballer44 on AIM
Old Apr 27, 2002
GOTSPRINGROLLS's Avatar
Super Member
GOTSPRINGROLLS is an unknown quantity at this point
WOW thanks man!
get well![IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old May 1, 2002
ce01cvcex's Avatar
ce01cvcex is an unknown quantity at this point
a suggestion on sealing the sub enclosure. i would still caulk it, but after caulking, you can spray it with spray-in bedliner (available at most auto parts stores $10-$25) to give you a more airtight seal, then carpet it.
Old May 5, 2002
slowroll's Avatar
slowroll is an unknown quantity at this point
can u use a store bought box too?
Old May 7, 2002
mohawkboom's Avatar
not for a custom trunk setup..then it wouldn't be custom now would it [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Cheers
Mohawk
Old May 7, 2002
trevor's Avatar
trevor is an unknown quantity at this point
2k2civicballer.........THANK YOU.......you helped me grips,.....
[IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old May 7, 2002
slowroll's Avatar
i dont even know what i was talking about, im just dumb....but does this kind of box make a difference with the sound at all like make it less deep. Would it be worth it to do it with 1 solo baric 12" or would i be better off using a big ported box
Old May 7, 2002
trevor's Avatar
no....I dont think solobaric are ported,,,,,Im pretty positive.
My JL require small sealed....thats what the solo requires I believe.
If I were you I'd do it. Not ported.
My system w/ this box thumps SOOO hard,.......I don't even bump it that loud......maybee to show somone every once ina while...but hardly ever......Its a good design....go for it.[IMG]i/expressions/beer_yum.gif[/IMG][IMG]i/expressions/beer_yum.gif[/IMG][IMG]i/expressions/beer_yum.gif[/IMG][IMG]i/expressions/beer_yum.gif[/IMG]
Old May 12, 2002
02CivicEX's Avatar
02CivicEX is an unknown quantity at this point
The square solobaric subs can be ported or sealed, there old one's (round) i think are just sealed. I have two 2002 12" square solobarics--Im in the prosses of building my ported box's- i have to build two because of our trunk design
Check out www.kicker.com if u need info on these subs
Old May 17, 2002
Cristo's Avatar
Cristo is an unknown quantity at this point
Don't do ported.......do sealed.....you get the same bass sound except its tighter, it really punches and it sounds alot louder
Crazygrlinak
Oct 8, 2015 05:06 PM
carid
Sep 28, 2015 10:13 AM
Sep 27, 2015 11:33 AM
General DIY
Sep 25, 2015 08:02 PM
speedlever
Sep 24, 2015 07:18 PM
