2003 Civic LX Lock Problem
Old May 18, 2009
shmike21's Avatar
shmike21 is an unknown quantity at this point
So I have a problem with the locking mechanism on the driver's side door. It would seem that the only way I can lock or unlock the door is with the keyless entry or when the door is closed and I use the power lock button. I cannot manually lock the door with the latch or use the key in the door to lock or unlock. So I had the door panel off trying to figure out the issue, already tried WD-40 which did not work. But I noticed that the metal bar attached to the inside door handle affects the ability to lock or unlock the door manually. If I pull on the inside handle just a little bit, I can use the manual latch on the door and the key works in the door. But when the handle is in its resting position, it doesn't work. Only the keyless entry. Does anyone have any ideas as to how to fix this? Thanks
Old May 19, 2009
electric130's Avatar
Re: 2003 Civic LX Lock Problem
you can't fix it. that's normal operation the way honda designed it. it's to keep people from locking their keys in the car. you can pull the handle and hit the power lock or the lever, but that's it. thats the way it's supposed to be.
Old May 25, 2009
shmike21's Avatar
I thought that at first too. But that doesn't explain why my key doesn't work in the door. It works fine in the passenger door. And it will work if i pull on the handle a bit from the inside. The key is fairly new, within the last year.
Old May 26, 2009
whitealexander's Avatar
whitealexander is an unknown quantity at this point
yeah.. i always leave my keys behind but thanks to this system i can retrieve it..
Old May 26, 2009
could have been cut slightly off or something.
Old Jun 13, 2009
Stearic's Avatar
Stearic is an unknown quantity at this point
I believe that's still SOP for the door and the locks. I think it's got to more with the door latch knowing if the door is shut or not when it comes to if you have to have the handle pulled to lock it when the door is open either via pushing down on the lock from the inside or using the key to lock it from the outside while the door is open. I've tried this out my self when i first noticed it (after the actuator died on me).
Old Jun 13, 2009
bigaudiofanatic's Avatar
bigaudiofanatic is an unknown quantity at this point
I am having a simulator problem my lock actuator is not locking or unlocking.
usajags84
May 10, 2015 08:11 AM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
Fastfebur
Apr 22, 2015 01:37 PM
dooner24
Apr 14, 2015 07:51 PM
deus-ex
Apr 13, 2015 12:29 PM
