02 Civic Si : Alpine deck dims when headlights on.
Old Apr 18, 2009
malum's Avatar
malum is an unknown quantity at this point
I have my alpine deck hooked up, while I was installing it i found there are no dimmer wires, and some other minor things I don't care about. Either way the deck is working just fine except when I turn my headlights on the deck dims significantly. Is there any way I can stop this from happening?
It's not a huge problem , but when it's dark enough that I have to turn my headlights on, but still light enough that the sky is still lit, it makes it difficult to see my display.
Does anyone have a clue if there is a fix to this? Or is it just tough luck?
Old Apr 18, 2009
DUI Elite's Avatar
DUI Elite is an unknown quantity at this point
Re: 02 Civic Si : Alpine deck dims when headlights on.
im guessing its tough luck...
the load on the battery from running all the lights is whats doing it... Are there any settings for dimming on the Alpine deck?
Old Apr 18, 2009
well it really sounds like you hooked up the dimmer wire. i ended up disconnecting mine cause i wanted it bright all the time. just figure out which one is for the dimmer (or illumination) and cut it.
Old Apr 19, 2009
civicplaya's Avatar
civicplaya will become famous soon enoughcivicplaya will become famous soon enough
What wire are you supposed to splice the dimmer wire into?
-Thanks
Old Apr 20, 2009
i dont think the dimmer wire is used on our cars. its the illumination wire that controls how the deck dims when dash lights come on. and to figure how to connect it, you need your radio install diagram and the stock harness connector diagram to match them up.
Old Apr 23, 2009
cwo715's Avatar
Falken Master
cwo715 is just really nicecwo715 is just really nicecwo715 is just really nicecwo715 is just really nice
yeah illumination wire. my kenwood head unit dims as well when the parking lights switch over to on, i just turned this off in the Menu. If you have the owners manual check it out
Old May 27, 2009
malum's Avatar
ROFL. Ok I'm no idiot when it comes to the wiring of a system, that's why this had me stumped. This damn deck has an option to dim when i turn on my headlights, I guess since it's so damn bright at night. I laughed my *** off at myself when i figured that out. It's just this new model civic i had has different wiring then my old one, it doesn't have 2 that my old 99 hatch did.
Silly me.
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
shaejb15
Apr 26, 2015 07:44 PM
civic_gt
Apr 19, 2015 08:15 AM
SSMatey
Apr 13, 2015 06:09 PM
NukeSilo
Nov 4, 2001 09:37 PM
