Weird Static Problem
Old Mar 28, 2009
Retell's Avatar
Retell is an unknown quantity at this point
I currently have a Pioneer AVIC-F700bt. A few days ago I bought a wiring kit to put in a second amp, ever since I get really bad static and squealing in my speakers. The squealing seems to come from the alternator every time accelerate. The static is horrible when trying to hear voice directions. I have since tried new amps, new speakers, new RCAs, ground loop filters, noise filters, ground head unit in trunk, removing the wiring kit, and even a new head unit. The only thing that seems to remove the static is if I take one of the audio out female RCAs and touch it to the metal on the head unit.
In the last day it seems to have gotten worse, when I do not touch that RCA to the metal, I have what sounds like a crossover problem, I can't get any vocals out of my speakers.
I have a feeling that my head unit is now starting to go
Old Mar 28, 2009
PaCiFiKbAllA's Avatar
PaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond reputePaCiFiKbAllA has a reputation beyond repute
Re: Weird Static Problem
Was it a used deck when u bought it..cause even Pioneer's cheap **** doesn't crap out like that...it definitely sounded like you had a bad ground or one of the RCA cables were cut somewhere along the line...did u double check the speaker wire connections...and you don't need ground loop filters or noise filters in our cars...i assume u have a 7th gen honda?
Old Mar 28, 2009
Retell's Avatar
I have tried brand new rca cables run straight to the amp with no hiding. The deck was brand new bough about a month ago.
Old Mar 28, 2009
civicplaya's Avatar
civicplaya will become famous soon enoughcivicplaya will become famous soon enough
That is weird... i do know if it sounds like the static is going up and down with the rpms, then it is your RCA's. But i'm not to sure what it could be since you replaced them. I'll do a little research and get back to you.
Old Mar 28, 2009
Retell's Avatar
Thank you very much, I am planning on ripping everything out tomorrow to investigate further!
Old Mar 31, 2009
Retell's Avatar
I forgot to mention a very important part. The wiring kit came with a 1.2 farrad cap. When I wired it up the cap made a loud noise then blew the 100amp fuse. I since removed all that and get the problem.
IB Jose
Site News
Jun 2, 2015 12:58 PM
mrohitredd
May 30, 2015 06:51 PM
mrohitredd
18
May 14, 2015 07:35 PM
tylerginevan
Apr 27, 2015 12:29 PM
cdt12271
Apr 23, 2015 11:36 AM
