Has anyone used the yellow fog lamps from Ebay?
Old Jan 27, 2009
02_civiclx's Avatar
02_civiclx is an unknown quantity at this point
Hi,
Just got my 02 Civic LX 4Dr and will be using it for commuting over the Altamont Pass in Northern Cali that gets heavy fog in the mornings.
Anyway, has anyone bought and used the "Yellow Fog Lamps" from Ebay? It says, it fits non Si models.
Will this do the job of providing ample fog lighting?
Thanks!
Name:	OEM Fog Lights.jpg
Old Jan 27, 2009
Re: Has anyone used the yellow fog lamps from Ebay?
its more for show, like 90% of oem fogs. you might get a tad more foreground light, but dont expect miracles. if you want a decent fog you have to go aftermarket like hella micro de and those get expensive. but these yellow ones will still make your car a bit easier for others to spot.
Old Jan 27, 2009
BJanzen's Avatar
BJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of lightBJanzen is a glorious beacon of light
Wouldn't hids make the fogs worthwhile?
Old Jan 28, 2009
it would also blind everyone on the road. the oem fogs already do a great job of throwing glare everywhere without hid.
Old Jan 28, 2009
TRIZ's Avatar
I have them, they suck. You can only see maybe 6 inches beyond your hood if you sit up as straight as possible... they suck *****. You'r better off doing a projector retrofit on them... and get clear fogs, the yellow ones end up looking like ****. I hate them now and when I bought them I thought they were the coolest thing in the world.
Old Jan 28, 2009
02_civiclx's Avatar
This sucks! I really don't wanna spend more than $50 and I dread drilling and cutting into the bumper thats why I'm considering a factory fit.
So, the yellow projection you get from this set has 0% effect on the fog?
Did they use a 55W or lower?
Thanks!
Old Jan 28, 2009
MidnightCivic's Avatar
ive got them on the civic..I think their worth the money..but if you want something that will project it even further go with oem..i still like mine
Old Jan 28, 2009
ProjectSkyy's Avatar
ProjectSkyy is an unknown quantity at this point
within 6 months my yellow ebay fogs had a rock go straight through the front plastic.
Old Jan 28, 2009
Also forgot what bulbs i have..either luminics or nokya..i think gearbox had recommended them..
Old Jan 28, 2009
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
I'm thinking about getting these as well, keep the experiences coming.
Old Jan 28, 2009
02_civiclx's Avatar
Thanks for the pic MidnightCivic. I'm gonna order mine today as I definitely need more lighthing especially going through the fog at Altamont.
Ebay has em shipped for $45 through Gforce.
Old Jan 28, 2009
like triz said even with the real expensive oem fogs, you only get extra light 5-6 inches beyond the bumper if you sit straight up. if your lying back, no light. they suck for any practical purpose, except glaring other drivers. if you are looking for a real fog light, those have very bright foreground light and wide beam, but you will be struggling to see into the distance. good fog lights are for severe weather only, and should be used without the headlights. even if you buy the best fog light in the world, youre gonna have to slow down. i used to have projector fog lights that were brighter and projected further than my headlights. but i never used em at all and ended up ditching them for a show version just for looks. with the best fogs, you will not be able to see anything past their foreground light, maybe 20 ft in front of the car. in 90% of driving conditions, its best to just use your lo beams.
heres a pic of my old fogs, nearly double the output of the stock headlamps. but it just didnt make sense to have that much light. in fact every time i would try to use them, i felt more scared of hitting something i couldnt see.
Old Jan 28, 2009
Clean 03's Avatar
Clean 03 will become famous soon enough
Clear lense, yellow bulbs. Only used them in really bad fog 2 times going upstate ny. Couldnt even drive with my low beams on it was so thick. With just the fogs i was able to drive. Obviously slower and more cautiously than normal, but i could see and i got home. Heres a pic. they dont glare like that and they're not blinding. its just the way the pic came out.
Old Jan 28, 2009
Are those the retro-fitted fogs? looks nice
Old Jan 28, 2009
youngjosh12's Avatar
youngjosh12 is an unknown quantity at this point
Hey, I bought them and I like them. They're not really all that bright on the road, but it adds a lil light on the sides of your car. They are just more show, but they last a long time. I gotta order more though, the yellow covers cracked when it got like 34bellow here but ill be ordering more once it actually gets warm here. just my 5cents
Old Jan 28, 2009
Geek-Squad-Man's Avatar
Geek-Squad-Man is an unknown quantity at this point
I got them for my 05 2-door-
They are OK, the problems are:
They break easy
They don't just bolt in like a stock Honda part would
They came with absolutely shitty bulbs and I had to fork out 35 more for bulbs
The "factory" style switch they came with took EXTENSIVE mods to make it fit in the dash and work
you have to cut the thick plastic inserts molded into you bumper cover
they are just curved yellow plastic, with no proper "lens" so they just blast light out in every direction -except the one you need (forward)
the way they came wired- the light inside the switch was on 24-7 not just when the key was on, I had to re-do it
The Pros are:
They are cheap $$ ( i bought my second set thanx to the ******* that lets his dog commit suicide in front of me a cpl weeks ago)
the wiring is nice and the plugs fit right in the fuse-block
they do look cool?
you get everything in one kit and don't need extra brackets and crap (besides needing new bulbs)
Old Jan 28, 2009
yeah but i dont have em like that anymore. theyre blacked out inside and no shield, its just for show with yellow bulb. at least then i can use em without adding more light in the foreground
Old Jan 29, 2009
electric130's Avatar
even with OEM style, you'll still have to cut at least part of the bumper to make them fit on an 02. there's instructions floating around this site that shows what you have to cut. it's more than just the small black section though. you'll have to cut into the painted area. better hope you don't cut too much! after analyzing all this, i decided to get the blazer projector fogs and put HID's in them. there's a link in my sig about how i did mine. i still have an extra set of the projector fogs i never used. i bought 2 sets, but never bought the truck i was going to put the second set on.
Old Jan 29, 2009
how are those holding up? i know a few guys burnt the chrome off using hid kit in blazers.
Old Jan 29, 2009
TRIZ's Avatar
You suck. I just pulled up pics of your hid fog retrofit and that feeling I burried months ago came right back. PM me links to the fogs and HID kit you bought would you. I think I'll look at doing this for really this time. My fogs cracked so why not.
Old Jan 29, 2009
DDragon7's Avatar
I also have Blazer fogs with HIDs, so far they have held up fine in the winter conditions.
http://www.7thgenhonda.com/forum/sho...ghlight=blazer
Old Jan 29, 2009
caleb1625's Avatar
caleb1625 is an unknown quantity at this point
i have these lights. they don't look yellow in the pictures, but they are pretty bright in person. for $30 you can't go wrong. plus, you can always change the bulbs themselves if they aren't bright enough
ID:	75672   Click image for larger version
ID:	75673   Click image for larger version
Old Jan 30, 2009
dma001's Avatar
dma001 is an unknown quantity at this point
Mine are eBay clear lens fogs with an OEM switch and Luminics yellow bulbs. Like some of the other guys have said, it's mostly a "fill-in" sort of light, mostly on the sides. I've just gotten another set of Luminics, Ultra White, and I'm going to try them just for comparison; I do like the yellow light, though.
Old Jan 30, 2009
almost 2 years now and they're still great. i need to update some pics. i've got 17's and an OEM spoiler now too.
Old Jan 30, 2009
dma001's Avatar
Well, I tried the Ultra White Luminics bulb (left), and it's okay...it's a nice "white" white, not bluish. It actually almost matches my SilverStar Ultras...
The only thing is, it doesn't seem as bright as the yellow Luminics bulb I have in there already (right). So, after about 15 minutes, I put the yellow bulb back in. Oh, I saw that somebody here installed yellow parking bulbs, and I thought it looked pretty cool, so I copied 'im
Old Jan 31, 2009
I dont know about geek-squad-mans order, but mine fit perfectly in my 02 sedan, I even just used the stock wiring harness. It was litterally one plug, 4 screws, and they were in. No cutting or anything of any sort!
Old Jan 31, 2009
01-03 and 04-05 have different shape, different mounting, etc.
Old Jan 31, 2009
Yeah, but just as long as you order the right set (for your year) then I'm pretty sure you would be fine, well at least for the 01-03 cars they should bolt in fine
Old Jan 31, 2009
I put mine in a 05 VP that had no wires, no plugs and no switches from the factory, I had to run it all (it all came with the kit)
And that would explain why they fit so poorly, their prob for an 03 style, cause they fit horribly in my 05-
Old Feb 1, 2009
DDragon7's Avatar
01-03 fog lights are oval shaped and not triangular.
