ground noise
Old Dec 21, 2008
rdzlyz's Avatar
rdzlyz is on a distinguished road
ground noise
i checked grounds, deck power str8 from the battery, ground for deck is on a different point of the chassy. my deck has a built in noise filter, which is attached on the yellow power cable.
i have two amps, 1 for sub, 1 for speakers, 1 capacitors, 2 power distribution block, so both are on one power and one ground, the ground is on the chassy right behind the back seats.
im running a 2ga wire for power and ground
and i still get noise.
it doesnt annoy me but it will be great if i dont have noise.
Old Dec 21, 2008
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
Re: ground noise
are your RCA wires close to your amp power wires? im no expert but my buddy had a grounding noise and to fix it all we did was move the RCA wires away from his power wires.
Old Dec 21, 2008
electric130's Avatar
Re: ground noise
yeah, power/ground wires on one side of the car. RCA's on the other side. if they do have to cross, cross them at right angles to each other.
Old Dec 21, 2008
rdzlyz's Avatar
Re: ground noise
nope they dont cross, when you open the seats at the back, my power and ground is on the left and the RCA's are on the right, they dont cross.
is there another place where i can ground the GROUND LOL instead of behind the seats...
Old Dec 21, 2008
rdzlyz's Avatar
Re: ground noise
it maybe my EQ, it may be defective, because if i just hook up my lines directly to the amp its fine...
when i hook up my lines to the eq with the eq off the noise is still there.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
15EXCoupe
Jul 30, 2015 12:59 PM
BootyDo
Jul 26, 2015 10:38 AM
LorenzoC0395
Jul 14, 2015 08:46 PM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
