burnt out headlight
Old Dec 2, 2008
Fox04coupe's Avatar
Fox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond reputeFox04coupe has a reputation beyond repute
burnt out headlight
what do i need to do to replace a burnt out headlight?
Old Dec 2, 2008
metalviper's Avatar
metalviper is just really nicemetalviper is just really nicemetalviper is just really nicemetalviper is just really nice
Re: burnt out headlight
get a new bulb
Old Dec 2, 2008
BigVic4545's Avatar
BigVic4545 is an unknown quantity at this point
Lol yea it's pretty simple...buy a new bulb and replace it by removing the rubber grommet then unclip the light bulb....after you unclip it you remove the factory plug (assuming you have halogen bulbs)....then put in new bulb.
Old Dec 2, 2008
manahoonie's Avatar
look at page 247 of the owner's manual...
if not on that page, check index...
YES! the Owner's Manual actually tells you how to do things too!
Old Dec 3, 2008
electric130's Avatar
buy new bulbs. remove old ones. put in new ones. always replace them in pairs. if one went out, the other one is likely about to go out to. do them both and be done.
Old Dec 3, 2008
EXsmellsbetter's Avatar
Mr. Treehorn treats objects like women, man!
EXsmellsbetter has a spectacular aura aboutEXsmellsbetter has a spectacular aura aboutEXsmellsbetter has a spectacular aura about
And whatever you do don't touch the new bulb or your hand oils will cause it to explode (after like a month of use)!! Or so I've heard. I didn't touch mine so I don't really know.
Old Dec 3, 2008
TRIZ's Avatar
And if you do use it, wipe it down with a new super microfiber towel and alcohol.
Old Dec 13, 2008
Fox04coupe's Avatar
yeah i did it and damn they were really in there good, i had to use a pair of channel locks on one... it was overy simple might i add.
Old Dec 16, 2008
lakerecrider's Avatar
lakerecrider is an unknown quantity at this point
LOL ya just get something and if you go aftermarket make sure the output is bright enough and that they are not junk.
rnaodm
Sep 21, 2015 12:42 PM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
dantheman42
Sep 4, 2015 01:10 PM
