Keyless remove entry messed up
Old Aug 18, 2008
eatingnachos's Avatar
eatingnachos is an unknown quantity at this point
I've got an 05 civic si and both remotes are messed up. they won't lock the car but unlocking works fine. tried new batteries but it's the same.
any help?
thanks.
Old Aug 19, 2008
Re: Keyless remove entry messed up
More info. I found these instructions and it all went well as far as programming the remotes--except the same problem exists. I'm thinking it's not in the remotes (duh) but where else do I look next?
Anyway, hope these instructions help someone.
Old Aug 19, 2008
Oh yeah, I forgot to post the instructions. Oops.
Only need to use 1 remote to get into program mode but all remotes must be programmed during the same session.
Each step must be completed within 5 seconds.
1. Sit in the car with all doors/trunk tightly closed
2. Turn the key to the ON position, marked by "II" on the ignition bezel so the dash lights come on, then within 5 seconds press the "Lock" button on the remote for 1 second or so and release the button.
3. Turn the key to the OFF position, marked by "I" on the ignition bezel - dash lights go off.
4. Repeat steps 2 & 3 three more times (A total of 4 times) - each step must be done within 5 seconds of the previous step.
5. Upon the 4th turning of the key to "ON", press the lock button on one remote, the locks will make a cycling sound (clunk), locks will NOT lock or unlock at this point, they will just make a noise. The system is now in programming mode. Do not turn key off.
6. Within 5 seconds of entering programming mode and within 5 seconds of each other, press the lock button ON EACH remote you are programming, for a second or so and release. This step needs to be completed within 10 seconds. Each time a remote button is pushed, the locks should cycle. Up to 3 remotes can be programmed.
7. Turn ignition completely off and remove the key. Step out of car and close door. The remotes should be programmed and should work. If you have a trunk/hatch release, the button for this feature needs to be held for a few seconds before the trunk/hatch will "pop".
Ariah J. Davis
Jul 20, 2015 07:15 AM
bizspeed
Florida
Jul 14, 2015 08:40 PM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
Causemo
Jul 5, 2015 06:42 AM
Causemo
Jul 4, 2015 07:11 AM
