Maybe a cut amp line from terminal
scratch my last post. So i have this wire that looks like an amp line that is connected to my negative terminal of the battery that ends up under my passenger side seat. The funny part of this wire is... its all cut from the side that comes up under the seat. So im wondering if i should detach the wire from my negative terminal...or just leave it as is. Thanks.
*and im not sure about the thing being an amp line or not because its just a bunch of wires that are cut coming from under the seat, and i have another thing that says "streetwire" that looks like a tube in my engine bay. I'll get a picture later.
Re: Maybe a cut amp line from terminal
I don't get it. Is there an amp under your passenger seat? Or is it just a ground wire from the battery's negative terminal to the bottom of the seat which is connected to nothing? If it's not connected to anything, just take it out. Maybe the previous owner had an amp under there and took it out, but left the wires there.
Streetwires is a manufacturer of aftermarket wire so it's definitely not OEM. If the other end of the wire is not connected to anything, pull it out for sure.
breanna_17
Jul 21, 2015 04:01 PM
Bill in San Jos
Jul 10, 2015 12:32 PM
JustaRhymez
General 7th Gen
Jul 10, 2015 07:12 AM
