Blue Center Dash Controls
Old May 19, 2008
WgnrNick's Avatar
WgnrNick will become famous soon enoughWgnrNick will become famous soon enough
http://cgi.ebay.com/ebaymotors/_Car-...m230253238553&
Can anyone shed some light on this? I can solder and whatnot but I don't know whats behind that thing to know that what the kit comes with will be enough/ will make it work. Thanks for any help!
Wagner
Old May 19, 2008
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
Re: Blue Center Dash Controls
There's a D.I.Y. writeup on this forum explaining how to do it. Basically all you need to do is make sure you have the correct LED and resistors for our boards.....which it looks like he's already picked out for you and included with the kit. Then you simply cut off your red LED and solder on the new blue ones in their places, testing it between each addition to make sure the LED is not on backwards. Once they're all on, reinstall.
Old May 19, 2008
WgnrNick's Avatar
Sweet, thanks for the help Dex!
Wagner
Old May 19, 2008
DeX's Avatar
DeX
Canadian, Eh!
Always here to help! And today's slow at work so I'm posting every 2 minutes.
Old May 19, 2008
DeX's Avatar
DeX
Canadian, Eh!
****, I'm in a giving mood....
https://www.civicforums.com/forums/1...sh-lights.html
I even bought the homeless guy on the corner a $12 breakfast this morning.
Old May 19, 2008
WgnrNick's Avatar
Ha... +1 for helping the homeless, lol. Anyway, do you think I could just use butt connectors instead of soldering. I have a solder gun bit its mad old.
Wagner
Old May 20, 2008
DeX's Avatar
DeX
Canadian, Eh!
No idea what a butt connector is.
Old May 20, 2008
WgnrNick's Avatar
You put one wire into one side and the other wire into the other side then crimp the metal insert in the middle to connect the two.
Wagner
Old May 20, 2008
DeX's Avatar
DeX
Canadian, Eh!
haha, that's ghetto!
Could you? Yes. You'd still have to solder a piece of wire to the LED though because they just come with 2 pins sticking out of them and you solder the pins to the board. So in order to get something into a butt connector, you'd have to extend the metal pin by soldering a wire to it. Plus you'd have no way to aim it, if you do it that way the LED could bang around and be facing any way under the cluster. If the pins are soldered to the board, it's always facing out all the time.
Soldering irons are like $20 at Home Depot, I picked up one last year.
Old May 20, 2008
WgnrNick's Avatar
I'm confused... Ah, could you find a pic of what your talking about? I understand the pins on the back of the LED but what do I solder that to?
Wagner
Old May 21, 2008
DeX's Avatar
DeX
Canadian, Eh!
The post and the anvil are what you're going to need to solder to the board. So if you can get that into a butt connector, go for it. It'll be a shitty install though and you'll be unhappy with the lighting afterwards. It'll be much easier to get those into a butt connector if you extend the post and anvil by adding a piece of wire to each one, that way they'll be longer and farther apart. But you're better off just soldering these pieces to the board, irons are really cheap now. You can get one that uses butane but if you're close enough to an outlet, I'd use one that plugs in. My butane one clogged up after like 1 month.
Actually you're not too far from me, if you want to roll up to New York I can do it for you.
Old May 21, 2008
WgnrNick's Avatar
Ha, thats quite a roll. When you refer to the board you mean? (Sorry I have yet to shank the whole thing apart. I just know what to expect/do when I do buy the stuff). Will I yank the old LEDs/ lights off and solder on the knew ones?
Thanks!
Wagner
Old May 22, 2008
DeX's Avatar
DeX
Canadian, Eh!
Did you follow the link I gave you? You take the old LED off of this and solder your new ones in.
Old May 22, 2008
WgnrNick's Avatar
Ha, did you follow the link I gave you? Is there boards for these too?
Wagner
Old May 22, 2008
DeX's Avatar
DeX
Canadian, Eh!
Ha, touche my good man, touche! I just searched for 10 minutes to find it for you. There's a few that did it but the links to the D.I.Y. they provided are broken so it didn't help. Some other douchebag did it but didn't post pictures so I didn't even read it. So I guess after all this time the answer is no, I don't know how to do it. You'll just have to pull off the dash piece, pull out the L.E.D, snip them off the circuit board and solder on new ones with the correct polarity. It really is pretty straight forward.
Old May 22, 2008
Unevolved's Avatar
Rough, Tough, Real Stuff.
Unevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to behold
Good God. I don't think this problem will ever end for me. I've been fighting this for quite some time trying to find a good solution. Let me assure you that hacking up the plexiglas diffuser will not work, nor will replacing it with a breadboard with LEDs mounted on it in an parallel array.
The main problem with getting an even light output is the incandescent bulbs in there now are omnidirectional, but LEDs have a relatively narrow angle (60 degrees or so) that they put out light.
Is there anywhere that might sell blue incandescent bulbs about the size of the existing ones? I don't give a damn about power consumption on this level.
ClapAlongChorus
Electrical
Oct 28, 2021 10:50 PM
KronikScott
Jun 9, 2015 08:00 PM
IB Jose
Site News
Jun 2, 2015 12:58 PM
SugarRay
Dec 6, 2001 05:17 PM
SugarRay
Dec 1, 2001 06:12 PM
