Smartphone's Audio & Power in car: Electrical Noise
Old Mar 17, 2008
KD5FTN's Avatar
KD5FTN is an unknown quantity at this point
Question Smartphone's Audio & Power in car: Electrical Noise
I've got a problem when I plug my phone (HTC Titan/Sprint Mogul) into my car stereo as well as cigarette adapter.
I'm also got a kind of custom setup using HTC Y Adapter with a 2.5mm jack and MiniUSB jack. The phone only has a special miniUSB connection that carries both audio and power, hence the Y-adapter.
Audio
2002 Honda Civic Stock Stereo -> CD Changer to Aux Input Adapter -> 3.5mm to 2.5mm adapter -> 2.5mm input on HTC Y adapter.
Power
Belkin Cig. Lighter to USB Female Port (From old iPaq) -> HTC Stock Sync/Charge USB cable -> MiniUSB input on HTC Y adapter.
So, when both the power and audio are plugged in, I hear a horrible hiss on my car stereo, not to mention a sound that varies in pitch to my throttle. When I unplug the power, the audio is completely clean. To me this seems like some kind of a grounding issue - to say that the Audio and Power both have seperate grounds, and bridging the two creates a potential difference in the form of noise on my Sound. Also to note: I only hear the noise when the Y adapter is plugged into the phone. With the audio and power plugged into the Y adapter, but the Y adapter not plugged into the phone, It's perfectly clean. I'm kind of baffeled.
The only solution I can think of is to gut the Belkin Power->USB adapter, and providing it from 12VDC elsewhere. I've got a tap directly below my passenger seat where I have a big power inverter tied to my battery. I don't know if I'd hear the same sound by grabbing my power from there.
Anyone with an engineering mindset have an idea? I'm open to suggestions.
Old Mar 30, 2008
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
Re: Smartphone's Audio & Power in car: Electrical Noise
Yes, and yes.
h4ldol
Jun 3, 2015 03:26 PM
anddrrey
May 11, 2015 02:30 PM
cloudguy
Apr 28, 2015 05:02 AM
SSMatey
Apr 13, 2015 06:09 PM
