Question-Hardwiring LED's & Neon
Old Mar 18, 2008
bhoward3's Avatar
bhoward3 will become famous soon enough
question.... i have a neon running from the sub box in the back of the car and it was a plug into the cigarette adaptor ones... i cut the cigarette adaptor off in order to hardwire it....but i dont know how to.
i can bring the wires up to the dash easy, but i dont know what to hook each wire to? can someone provide an easy detailed explanation, when it comes to electricity im a complete noob. diagrams confuse the **** out of me. i just want the neon to be on when the car is turned on.
my car is a 2003 honda civic EX
Old Mar 18, 2008
civicfan1203's Avatar
Look at me im a supporting member
civicfan1203 is just really nicecivicfan1203 is just really nicecivicfan1203 is just really nicecivicfan1203 is just really nice
Re: Question-Hardwiring LED's & Neon
Dont hold me to this but i believe you could just find a constant power source and hook it up but i wouldnt know how to do it unless i was actually there to do it i am more of a hands on type
Old Mar 18, 2008
sl33pyriceboi's Avatar
what you want to do, is take off ur center console and use "t-taps" and splice (tap) into teh cig wires. just make sure u get the postive and negitive right.
black is negitive...the other wire (usually red or yellow) is postive
btw, you can buy Ttaps anywhere...autozone, homedepot, lows...etc
Old Mar 30, 2008
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
Usually the inverter that powers the neon is inside the cigarette plug adaptor. It changes the low DC voltage of the car to hundreds/thousands of volts AC to run the neon. So most likely, you'll still need that part.
So put it back on and use a female cigarette lighter socket adaptor.
http://www.bestbuy.com/site/olspage....=1110266394715
frank_kleng
Sep 29, 2015 10:55 PM
MamaBear2015
Sep 24, 2015 11:34 AM
Klame9420
Sep 18, 2015 12:37 PM
Jrosa
Sep 14, 2015 08:24 PM
