DIY: EBAY FOGS... need a.s.a.p... HELP!!!
Old Feb 26, 2008
CIVIC_2001's Avatar
CIVIC_2001 is an unknown quantity at this point
WELL, Ive been searching around for a DIY for ebay fogs,
but most of the links provided are not working. Can some one
please help me find a link, or and article that has detailed
instruction on how to install them??? THANKS in advanced.
Old Feb 26, 2008
Spikez1222's Avatar
Spikez1222 is an unknown quantity at this point
Re: DIY: EBAY FOGS... need a.s.a.p... HELP!!!
Hmmm... never really found a link, but I'm running eBay fogs with Nokyo Arctic White bulbs... looks great... it's easy, just DIY without any instructions like me~! It's hard to make eBay foglights fit flush...
Old Feb 26, 2008
CIVIC_2001's Avatar
I'm going to try to put them in tonight. I ended up
getting a DIY for the 04-05 fogs, which should be
almost the same!
IF ANYONE HAS THE DIY FOR 01-03, LET ME KNOW
Old Feb 26, 2008
TRIZ's Avatar
Just adapt the install instructions for the OEM lights off of H&A
- View 2001-2002 4 door Installation Instructions
- View 2001-2002 2 door Installation Instructions
- View 2003 LX-EX Installation Instructions
- View 2003 DX-HX Installation Instructions
Take bumper off, dremel out holes for lights, install them with the mounting hardward provided in the ebay kit. The figure out the wire harness- one part is the ground, the other goes to a bround connector just under the passanger headlight - its probably covered in road grime so spend a few minutes looking for it. Then you need to decide how you want to wire them and do that. remove the center dash par- the one with the cig lighter part and the other side of that connector you plugged your fogs into is taped to the harness in there- its a slgihtly tricky find, but its taped there. From there you use that wire to wire it how you want. I used a seperate switch than what came with the kit because that switch doesnt fit and its garbage... autozone has them- the three pronged one - in/out/ground. Then just hook that up to an inline fuse to the fuse box. I think your set then. You can wire it several different ways. This will be kind of tough for you if you've never stripper a wire and dont understand the concept of grounding... if you've done wire work before you can make it through the install. Having a friend help is always a plug. Dont forget the six pack.
Old Feb 26, 2008
CIVIC_2001's Avatar
THANKS Triz! but wont i run in to some problems with the wiring since OEM are different than ebays fogs?
Old Feb 26, 2008
kuNhoHan's Avatar
kuNhoHan will become famous soon enough
what part of the valley you from???
Old Feb 26, 2008
CIVIC_2001's Avatar
ARLETA/PACOIMA AREA.... where you located???
Old Feb 26, 2008
Rennen's Avatar
New Mod on the Block
the wiring harness is probably not going to line up so you might have to find a way to power them yourself. i wired mine to my 12v accessory outlet.
Old Feb 26, 2008
Bb0iPn0y's Avatar
Bb0iPn0y is an unknown quantity at this point
http://www.honda-tech.com/zerothread?id=2058317
im proj3xt01v1c on honda-tech.com
Old Feb 27, 2008
Lord ET's Avatar
Lord ET is a glorious beacon of lightLord ET is a glorious beacon of lightLord ET is a glorious beacon of lightLord ET is a glorious beacon of lightLord ET is a glorious beacon of light
Here is the simplest way to wire them. You can just throw away the wiring harness that came with them if you'd like...That's what I did.
Connect the two positive terminals of the fog lights together and attach a wire to them that will go into the car (I routed the wire over my passenger tire and in through a rubber grommet). Next attach a wire to the positive terminal of your battery and wire in line with a 30Amp fuse (Amperage value may be different depending on how much current you draw.)
Amps = Watts/Volts
I chose 30 just because it's a common fuse even though it's overkill. You may also choose to use a circuit breaker instead of a fuse so that you can just reset it instead of buying another fuse. (you can get them at autozone or a hardware store.)
Wire both of these +12v wires to the corresponding terminals of your relay. It will be something like +12v supply and +12v output.
A small explanation of a relay: The reason for a relay is that most simple switches aren't capable of handling high current loads; A relay is. It is a double switch that, when turned on, closes the gate and allows high current power to flow from the source terminal the output terminal.
Next you will need to ground your relay and connect a wire that will supply the low current voltage to turn the relay on and off. You may choose to have this on/off wire connected to your headlights/parking lights, in which case just splice into the corresponding wire under the dash, or you may choose to have a switch so you can have your fogs on whenever you like (no headlights, low beams, high beams.)
If you choose to wire to a switch there are two options. You can either have the switch wired directly to the battery, in which case you'll need another wire to run to the engine bay, or you can splice into a wire that is only hot (carrying a voltage) when the car is on. I recommend the latter so you don't accidentally leave your fog lights on when the car is off and drain your battery.
As far as wiring the switch, simply connect two adjacent terminals (if the switch has terminals like the one below.) In the picture below the top wire doesn't actually need to be connected to anything. This switch works by connecting the bottom two pins together in one toggle mode, and in the other mode it conects the top 2 pins. So the pin that isn't going directly into the relay needs to either be wired to the battery or to a wire that is only hot when the car is on, as mentioned above. This supply voltage doesn't necessarily have to be +5V. It just needs to be what your relay is rated for. If you buy one at radioshack or some such store, there will be a wiring diagram on the back that will tell you.
After this is all done, you should be able to fire those puppies up! Good Luck!
Old Feb 27, 2008
CIVIC_2001's Avatar
Thanks for the info LORD ET. My friend and I just custom wired it directly to the battery. The harness they provide, doent even make any sense. I wired them to the 12v outlet as well.
Old Feb 27, 2008
Lord ET's Avatar
good to hear you got it figured out!
Old Feb 27, 2008
Civic_Racer9's Avatar
(SnOwBoArDeR | FoReVeR)
hey sorry my pictures are sooo large to send through email. but u can use the switch they provided instead of mkaing ur own switch
Old Feb 27, 2008
Lord ET's Avatar
Yeah, you can use the switch they provided. Just make sure you have a relay because most switches aren't capable of handling the power that fog lights require.
On another note the program I use to quickly resize pictures is Irfanview. www.irfanview.com
It's as simple as oping the picture in the program --> edit-->resize/resample-->choose resolution--> save
Old Feb 27, 2008
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
Is this them? They're $80 on Ebay, is that what they usually go for? Maybe I'll get some too.
Old Feb 27, 2008
DeX's Avatar
DeX
Canadian, Eh!
That means they're always on.....why not wire them to a switch?
Old Feb 27, 2008
Lord ET's Avatar
I got mine for $20
http://search.stores.ebay.com/MotorB...agenameZRC0022
Old Feb 27, 2008
DeX's Avatar
DeX
Canadian, Eh!
Originally Posted by Lord ET
They're still $47 shipped, not $20. And you have to replace the blue bulbs with white/yellow.
Old Feb 27, 2008
Lord ET's Avatar
sorry I posted the wrong link... Here are the ones I bought. http://cgi.ebay.com/ebaymotors/ws/eB...m=180183988492
Old Feb 27, 2008
Envy's Avatar
Diamond Member
Envy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of light
you mentioned wiring the switch by looping two pins and doing nothing with the other pin? or did i read it wrong? how does it connect to the relay?
does this work as well?
https://www.civicforums.com/forums/7...tch-relay.html
/End Threadjack
Old Feb 27, 2008
Lord ET's Avatar
/End Threadjack
I'm not sure I entirely understand that drawing, but what i was saying was connect one wire to the relay for the on/off voltage in (with low current) and the other side to a pin on the switch. Connect one end of another wire to a +12v source and the other end to the adjacent pin on the switch. The third pin on the switch needs to have nothing soldered to it so that the switch has an actual on/off function.
Look at the lower left hand corner of the drawing. That's what I'm talking about. When the switch is 'thrown' in one direction the slider inside makes contact with 2 of the three pins. Either the middle and left, or middle and right. One of the outside pins needs to not be connected so that when the slider is contacting that pin and the middle pin there will be no voltage passing through.
Old Feb 27, 2008
DeX's Avatar
DeX
Canadian, Eh!
Still $37 shipped. I think I'll get a set though, thanks. But Ontario, California.......I hate it when they do that.....
Old Feb 27, 2008
Envy's Avatar
Diamond Member
thank you! +1 for you!
Old Feb 27, 2008
DeX's Avatar
DeX
Canadian, Eh!
Are you guys talking about this switch being bad? I like it, it's like the OEM switch.
Old Feb 27, 2008
carter's Avatar
carter is an unknown quantity at this point
If i could connect it to turn on with the head lights... because i used a relay for my headlights and i still have one plug coming from the car that isnt used would the relay connect with that so i dont have to worry about a siwtch and jus do the postive and ground wire?
Old Feb 28, 2008
Lord ET's Avatar
honestly you should just be able to splice the low current +V wire from the relay onto the headlight +V wire.
^^ Dex, when I got that switch, it didn't work where I needed it to go. It was meant for the middle console but I've already got 2 switches there. I don't however have a moonroof so I wanted the switch to go there.
Old Feb 28, 2008
DeX's Avatar
DeX
Canadian, Eh!
Will it fit here?
Old Feb 28, 2008
Lord ET's Avatar
^^ No, that's where I placed my switch. I had to drill a hole in one of those placeholders and stick the switch in there.
Old Feb 28, 2008
DeX's Avatar
DeX
Canadian, Eh!
So if not here then where's the switch mean to go? The placeholders over the cupholders are the same size.
Old Feb 28, 2008
Lord ET's Avatar
In my car, the ones over the cupholders are larger...I'm not sure why, but they were. The switch would fit there, but not to the left of the wheel. ??
