DIY: EBAY FOGS... need a.s.a.p... HELP!!!
Old Feb 28, 2008
  #31
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
Re: DIY: EBAY FOGS... need a.s.a.p... HELP!!!
Would it work with the OEM switch from Honda? I'd really like a stock look.
And have you had any issues/problems at all with these lights? Anything.....
Old Feb 28, 2008
  #32
CIVIC_2001's Avatar
CIVIC_2001 is an unknown quantity at this point
^^^... The switch that came with the ebay lights started smoking. those things suck. I had to go to autozone and by a different switch meanwhile. I also want the OEM switch! does anybody know where i could get it for cheap?
Old Feb 28, 2008
  #33
Lord ET's Avatar
Lord ET is a glorious beacon of lightLord ET is a glorious beacon of lightLord ET is a glorious beacon of lightLord ET is a glorious beacon of lightLord ET is a glorious beacon of light
The OEM switch would definately work... and no, I've had absolutely zero issues with the fog lights, that wasn't my fault. (shorting wires during the install.)
Old Feb 28, 2008
  #34
DeX's Avatar
DeX
Canadian, Eh!
I already emailed Honda looking for a price on the OEM switch.
Old Feb 28, 2008
  #35
Lord ET's Avatar
it'll probably be liek $20 for no reason.
Old Feb 28, 2008
  #36
DeX's Avatar
DeX
Canadian, Eh!
$49.92
Old Feb 28, 2008
  #37
Envy's Avatar
Diamond Member
Envy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of light
http://www.hondaautomotiveparts.com
Old Feb 28, 2008
  #38
Lord ET's Avatar
http://www.hondaautomotiveparts.com/...08V31-S5P-120C
look at the 4th item from the bottom, you can change it to fog light switch, $10.05
Old Feb 28, 2008
  #39
Lord ET's Avatar
that link doesn't work right, it's actually on the second page, 4th from the bottom
Old Feb 28, 2008
  #40
DeX's Avatar
DeX
Canadian, Eh!
I don't see it on either page.
Old Feb 29, 2008
  #41
Lord ET's Avatar
Old Feb 29, 2008
  #42
DeX's Avatar
DeX
Canadian, Eh!
thanks
Internet Explorer 6? Wow.....
Old Feb 29, 2008
  #43
Lord ET's Avatar
It's on my work computer. I can't change it. I can do firefox, but it's more trouble to go around the admin. installation bs than to use IE6
Old Feb 29, 2008
  #44
Lord ET's Avatar
JIC you want them, these are the bulbs I ordered, they are more of a true yellow and they've been working great for me.
http://www.europeanautosport.com/yellow.htm
Old Feb 29, 2008
  #45
i moved my oem switch to where the cruise was cause its just a better place. i cut a lil material and it fit right in, then i put a bead of silicone around the back for extra strength. there is a tiny gap on the bottom, but you will never notice it looking from above. i have the ashtray and lighter in my console so it worked out well. i hated having those two stupid spacers there. and my cruise button is still connected and pushed on, its hiding in the dash somewhere.
Old Mar 3, 2008
  #46
r3gul8or's Avatar
r3gul8or is an unknown quantity at this point
Anyone have any idea which of those 4 part numbers would fit an Si or are they all the same?
Old Mar 3, 2008
  #47
Lord ET's Avatar
if it's the hatch SI then there is an option in that drop down menu
jdh022764
18
Nov 3, 2015 06:44 AM
zeshan7616
Sep 15, 2015 12:24 PM
rayman009
Sep 12, 2015 08:30 PM
Ultra Havoc
Sep 9, 2015 10:58 PM
Wheela
Wheels and Tires
Sep 7, 2015 02:14 AM
