subs go nuts when hit bumps
Old Jan 26, 2008
edrulz2003's Avatar
edrulz2003 will become famous soon enough
i drive and my subs just start blastin with bass and it wont stop til i hit the brakes to move my box around a lil...i think it might be a connection problem but dont know where ex. inside the box are the conections to the amp...its really annoying and wanna fix this...any help guys
Old Jan 26, 2008
greeen01civic4d's Avatar
Re: subs go nuts when hit bumps
check the ground first, then check the wires to the back of the sub box, i bet its a loose connection
Old Jan 26, 2008
chkolny's Avatar
chkolny will become famous soon enoughchkolny will become famous soon enough
^^agreed, im certain its the wiring, check the RCA and the ground wires
Old Jan 26, 2008
edrulz2003's Avatar
thx guys i will check the ground in the morning
Old Jan 26, 2008
Envy's Avatar
Diamond Member
Envy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of light
well if bass blasts, it just sounds like constant power/signal. So i bed itd be the RCA's.
Old Jan 27, 2008
electric130's Avatar
your box needs to be bolted down first. i used 2 hinges to mount mine to the car's frame behind the seats. i have a single 12.
i'd come up with a solution to immobilize the box before you worry about wiring problems. they'll only continue otherwise.
Old Jan 27, 2008
edrulz2003's Avatar
yea i know it needs to be bolted down but i like ur design alot so im gonna do that....thx for the help guys
Old Jan 27, 2008
mdawg's Avatar
mdawg is on a distinguished road
Thanks electric I have been pondering where I was going to bolt my subs too!
Old Jan 27, 2008
Alex857's Avatar
Alex857 has a spectacular aura aboutAlex857 has a spectacular aura aboutAlex857 has a spectacular aura about
Yeah man i bet its a ground connection problem or the Rcas.
Old Jan 28, 2008
Unevolved's Avatar
Rough, Tough, Real Stuff.
Unevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to beholdUnevolved is a splendid one to behold
Yeah, like someone already said, since they're firing, it's probably a signal wire rather than a ground wire. I'd check to make sure it's not just something as brutally simple as a loose RCA connector.
Mad Dog Tannen
Sep 12, 2015 12:48 AM
redcloud
Sep 7, 2015 01:45 PM
junkyardguy
20
Sep 6, 2015 10:07 PM
Stock 99
Sep 5, 2015 06:06 AM
hatch90
Sep 3, 2015 08:45 AM
