Which type of HID KIT ? for tyc projector for 05 civic sedan
hi i have jus purchased projectors for my 05 model civic.. they take h3 bulbs... where as on standard 05 sedan the bulbs are hb4/9006... ok so heres my problem .. i am about to purchase a HID kit and should i choose the h3 bulbs or the 9006? ... ok the reason to purchase h3 kit is that it will actually fit into the projector, whereas the reason to purchase the hb4/9006 bulb is so it can plug into the stock wiring but not fit the projector? get wat i mean? so which type of HID kit should i buy?
Re: Which type of HID KIT ? for tyc projector for 05 civic sedan
you have to get what fits the projectors. if you're worried about fitting the stock wiring, then you must not have a relay harness. i locked this because it has been covered numerous times before. get the H3 kit, buy a relay harness so you don't catch you stock wiring on fire, and you'll be set.
GaryFishell
Apr 24, 2015 06:49 PM
aus10
Apr 13, 2015 09:26 PM
