Speakers for 2003 civic sedan rear deck
Old Jan 7, 2008
decktard's Avatar
decktard is an unknown quantity at this point
I'm looking to replace my stock 6.5" speakers in the back of my 2003 civic sedan. I've already replaced my head unit, and two front speakers.
I've checked out crutchfield to see what fits for my car and it seems as though the list is pretty small. Any idea what the restriction is that eliminates so many speakers? It looks like there is plenty of room underneath in the trunk for a nice size magnet.
Does the top portion of the speaker bump against the rear deck plastic part?
Has anyone had any problems installing speakers into the back?
Could I do some small modification to fit in virtually any speaker?
Thanks!
Old Jan 7, 2008
0H3ebpEM2's Avatar
0H3ebpEM2 will become famous soon enough0H3ebpEM2 will become famous soon enough
Re: Speakers for 2003 civic sedan rear deck
rear speakers arent even needed. Its just rear fill. All you need is a good set of components up front and a nice deck. If you choose components for up front you should amp them.
What did you buy for your two front speakers?
Old Jan 7, 2008
decktard's Avatar
Honestly... I don't remember what I have for the front. They're some decent Kenwood 3-ways I've had from another car. So they're several years old now. I just didn't feel like doing a component install.
I wasn't going to break the bank on rear speakers, however; I wouldn't mind having a couple more options than crutchfield.com's adviser tool is saying.
Old Jan 7, 2008
i have infinity reference in the rear. and yes you need rear speakers, they provide most of the lower frequency sound if you dont have a sub.
Old Jan 7, 2008
Envy's Avatar
Diamond Member
Envy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of lightEnvy is a glorious beacon of light
theres a torsion bar in the trunk (in the coupes at least) that presents a clearance issue for the hanging magnet. You can relocate it by drilling into your wheel well if that is your fancy. Theres a DIY on here somewhere. Otherwise, theyll all fit. Crutchfiled said my 6.5" Alpines wouldnt fit in my front coupe doors. With the spacer/mounting bracket it came with, the driver side went straight in, and the passegner side requiered a little drilling/extrusion of the hole. All in all, good luck. You can also cut the torsion bar if you like, but that is not reccommended.
Old Jan 7, 2008
Maple50175's Avatar
Maple50175 is an unknown quantity at this point
I have infinity Kappas running to my amp and Love it!
vtec92
May 4, 2017 03:20 AM
Poopies
Apr 20, 2017 11:36 PM
usajags84
May 10, 2015 08:11 AM
Ian SFBA
Interior DIY
Apr 25, 2015 02:25 PM
aus10
Apr 13, 2015 09:26 PM
