Speaker makes a pop every 5 sec? Whats going on?
Old Dec 23, 2007
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
Hey everyone,
My audio system has been running flawlessly for the past couple of years and just recently, it has started to make a very annoying static type pop sound every 5 seconds, its not that loud so if I turn up the music I wont hear it but when my volume is at 0, you will still hear this.
Is this because of a bad ground? My speakers run from my deck, to a crossover that splits my tweeters and door speakers. (Rear speakers are not making this sound)
Could this be a ground issue? or maybe my wiring has come loose and theres a bad connection?
Old Dec 23, 2007
Re: Speaker makes a pop every 5 sec? Whats going on?
could be wiring shorting out or something. happened to my tweeters and idk why but i took the deck out and jiggled the wires and it went away. so idk maybe somethings touching metal when its not supposed to.
Old Dec 23, 2007
chkolny's Avatar
chkolny will become famous soon enoughchkolny will become famous soon enough
wow this is wierd i actually had this happen to my computer speakers about 3 weeks back, then the next day it stopped, i have no idea what the problem was at all, sorry. but do you have aftermarket speakers? if you do, take it wback to where you had them installed, you should have a warrenty on installation. (i know i did for mine), a bad ground is my best guess.
Old Dec 23, 2007
could also be a bad connection at the speaker plugs. my rears got so bad i had to cut the plugs off and just wrap the bare wire around the terminal so it wouldnt keep shaking over bumps.
Old Dec 23, 2007
Civicman1988's Avatar
check the connections by the speaker sometimes they get loose.
Old Dec 24, 2007
Nameless's Avatar
TURTLEonK
^ Sounds good! Thanks guys, I'll start with that... Just seeing if anyone had similiar problem hehe... I think maybe my door speaker connector probably came loose... Probably from all that opening and closing of the door lol...
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
GolNat
Suspension DIY
May 12, 2022 06:49 AM
dbagaus
Jun 10, 2015 09:29 AM
reqy
Jun 1, 2015 07:05 AM
cloudguy
Apr 28, 2015 05:02 AM
