I think I caused a shortage...
I was putting some new LED's in the trunk earlier and I accidentally mixed up the positive and the negative, and it sparked and smoked a little bit. Now the dome light and the map lights wont come on. Those are the only thing that won't come on though. Any suggestions?
Re: I think I caused a shortage...
yea check your fuses, and in the future, anytime you work on electrical components in your car, unplug the neg. terminal to your battery just to be safe
there is a fuse you can replace. i think its called small light fuse under the hood or above the brake pedal. check owners manual.
Look at me im a supporting member
see i had the same problem i think it was a relay cause i checked every fuse i could see but your situation is different then mine was i was installing a cd player for the first time and i made a spark and i lost all power options when the car was off every thing worked fine well my cd player didnt i wound up haveing to run my power to a fuse to get the cd player to work the one day i took it to honda for an oil change and when i got my car back every thing worked i dunno what they did but i didnt get charged for them fixing my car i was like score
its just one long sentence..lol jk
GritzNGravy
Aug 19, 2015 03:03 AM
fecrni
Aug 8, 2015 06:15 PM
jzhartman
22
Jul 23, 2015 10:42 PM
