How Do I Avoid Killing My Battery While Car Turned Off And Stereo On?
Old Nov 12, 2007
Jasdip's Avatar
Jasdip is a jewel in the roughJasdip is a jewel in the roughJasdip is a jewel in the roughJasdip is a jewel in the rough
Hey Guys,
How would I avoid killing my battery while my car is turned off and I have the music on? Would hooking a car battery charger up to the battery and plugging that in do the trick, or are there any other ways of doing this? This would be used if the car is going to be used for music while just sitting around to avoid having to leave the engine started..
Thanks!
Old Nov 12, 2007
spoonEM's Avatar
omgwtfbbq mod.
Re: How Do I Avoid Killing My Battery While Car Turned Off And Stereo On?
Just get a much stronger battery like a Yellow top or something along those lines. I have a Yellow top in mine and Ill leave the stereo running for long periods of time when im washing my car or something along those lines and I never have any problems.
Old Nov 12, 2007
chawski's Avatar
chawski will become famous soon enoughchawski will become famous soon enough
ha my battery is the only thing for my stereo i havnt upgraded yet, and boy do i need it! I have about 2 minutes worth of listening time without the engine on before i start losing power.
Old Nov 12, 2007
cinaibur's Avatar
cinaibur is just really nicecinaibur is just really nicecinaibur is just really nicecinaibur is just really nicecinaibur is just really nice
I had the same problem last week, then I got a yellow top and no more problem
Old Nov 12, 2007
civicfan1203's Avatar
Look at me im a supporting member
civicfan1203 is just really nicecivicfan1203 is just really nicecivicfan1203 is just really nicecivicfan1203 is just really nice
how much do those yellow tops rum i want one
Old Nov 12, 2007
DsevenEm2's Avatar
This is Myspace
Originally Posted by Jasdip
Hey Guys,
Thanks!
so, are u worried that your battery might die while u leave the radio on and car off, or has this happened before. If it hasnt died on you yet, or you havnt tried this, then dont worry about it. your car should last fairly long depending on what kind of stereo equipment you have hooked up and how old/new your battery is. if it has died before already, then buy a new battery. an optima would be your best bet. they range over 100$ though.. or close to that. I have a battery called Titanium? or something, and i go to drive in movies all the time and sit there for 1.5 - 2 hours with the radio on watching the flick. my car is turned off the whole time too.. and i have subs and an amp... soo.. go figure
Old Nov 12, 2007
cinaibur's Avatar
yellow top is $180 at autozone
Old Nov 12, 2007
i thought those got recalled cause they suck? mine only lasted lil over a year
Old Nov 12, 2007
spoonEM's Avatar
omgwtfbbq mod.
^ive had mine for over a year and a half, and I havent had a single problem with it.
Old Nov 12, 2007
ah, just watch out it could die at any time/ same happened to my friends civic we got ours at close to the same time.
Old Nov 12, 2007
lxcivic2k1's Avatar
2 years and going strong on a 51 series(I think, stock size) yellow top. I love it! Get it, if they still make it.
Old Nov 12, 2007
Jasdip's Avatar
Well my battery is really bad, it dies within minutes if I listen to music with the car off...even if i leave my headlights on (HID's) for about 5 min, the battery will die...sometimes if i'm listening to music loud and come to a stop and turn the car off without letting it run for a minute, it won't start up again either....but since its manual transmission, a good old push start does the trick...i'm usually careful though....
I would put in a bigger battery and replace the old one but I don't think it'll fit in the same spot, or will it? (I have a 2005 civic SI, canadian model..which is the 2005 Civic EX in the US) I don't really want to add another battery to the back of the car or anythin and have to wire that in and have to spend a lot of money on this...plus I think it would die pretty quick anyways if i'm listening to the music turned up loud and for a long period of time since my system draws quite a bit of power (ex. sittin around with buncha ppl and just pounding the music) I can't leave the car started because when we're usally in my wharehouse when I would ever do this, we jus pull the car in and close the garage door and the exhaust fumes just wouldn't be healthy lol...
but ya, there are plugs in there, I was looking for a way to just "plug the system in" so it would have power that way, rather than use the battery...
By the way, I have 2 Kaption Audio SPL-1200 subs with a Pheonix Gold Tantrum 1200.1 amp..and a 1 farad Pheonix Gold capacitor....the system draws quite a bit of power...
Old Nov 12, 2007
ultimatetuner10's Avatar
Technical Assistant
ultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond reputeultimatetuner10 has a reputation beyond repute
dry-cell battery
Old Nov 12, 2007
DsevenEm2's Avatar
This is Myspace
go get one of those Titanium batteries i told you about. and get rid of that capacitor, its a ****in waste of money. sell it because thats not helping u at all either..
Old Nov 13, 2007
Jasdip's Avatar
I want to avoid running the system from the battery when my car is turned off, would hooking a battery charger up work without damaging anything?
Old Nov 13, 2007
rednwhite04's Avatar
rednwhite04 will become famous soon enough
Optima FTW, keep killing your batt. and you will be purchasing an alternator soon...
Old Dec 13, 2007
WhiteRabbit's Avatar
if you want a FOOL proof solution, here is it:
Pick a sealed lead acid battery of your choice. SLA, GelCell, AGM, any of these buzzwords work. Install in your trunk and wire up to your distribution block. you need a battery terminal (on the positive side) with two terminals. The main power wire coming in goes DIRECTLY to the battery, then the second terminal goes to the stereo. Ground can be straight to the chassis.
Next, purchase an RV relay. its $20 and available at any RV fix it shop. Wire the contacts in series to the main line to the second battery. The coil is grounded on one side, the second side is hooked up to the fuel pump relay located just behind your glove box. you can probe the wires looking for 12 volts when the car is running. will float with the key in ANY position with the engine off.
Now you can run the stereo from the second battery until the car is DEAD.
But the battery under the hood is undrained and will start the car as normal. which will start the fuel pump, which will connect both batteries. Which then recharges BOTH.
No electrical outlet required.
and for the record, keep killing your battery and you will be buying a new BATTERY soon, not a new alternator.
Old Dec 13, 2007
wow that is very clever!
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
tylerginevan
Apr 27, 2015 12:29 PM
SSMatey
Apr 13, 2015 06:09 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
01civicboi
Bolt-on Engine Performance
Nov 2, 2001 07:33 AM
