Fried Amp??? I need help QUICK!!!
Old Oct 22, 2007
pnoyster2k1cvic's Avatar
Balut Eating Champ
ok, i turned on my car today but my subs doesn't work anymore... i checked my amp (i have an AUDIOBAHN A1300HCT 1000amp) it was working just fine yesterday and today it just stopped working...
-amp has power
-ground is good
AMP INFO:
600W@2ohms Max, High-Current Monoblock Car Amplifier
RMS Power Rating:
300 watts x 1 chan. @ 4 ohms
600 watts x 1 chan. @ 2 ohms
1200 watts x 1 chan. @ 1 ohm
Max Power Output: 2400 watts @ 1 ohm
Optional Wired Remote Bass Level Control Available with Blue Illuminated ***** (MODEL: ABR100T)
Also illuminates red to indicate when amplifier is clipping
High-Current, Non-Regulated Power Supply
Preamp Outputs
Cobalt Blue LED Illuminated Heat Sink Design (on/off switch for your preference)
Thermal Regulated, Air Induction Dual Cooling Fans
Double Sided PCB (Circuit Board)
High Gloss Chrome Plated Finish
Unique, Clean Chrome Fire/Flame Design
Blue Illuminated VU Meter Indicating Output Response
Clear Power and Speaker Connectors
Variable Bass Boost: 0-18dB @ 40-100Hz
Variable Low-Pass Crossover: 40-120Hz
Variable Subsonic Filter: 20-50Hz
Signal-to-Noise Ratio: 100dB
Frequency Response: 10Hz-40kHz
Phase Control: 0-180°
THD: 0.05%
Channel Separation: 50dB
Input Sensitivity: 200mV - 8V
I have no idea what's going on, do you guys know what's going on?... please help... i appreciate all the help...
Old Oct 22, 2007
DsevenEm2's Avatar
This is Myspace
Re: Fried Amp??? I need help QUICK!!!
have u checked the connection behind ur reciever? rca cables and what not.. try grounding at a different point.. have u checked the fuses in your amp?
Old Oct 22, 2007
FGCOUPE's Avatar
FGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to allFGCOUPE is a name known to all
to funny!
im just in the midst of installing a forums for this!
http://civicnation.12.forumer.com/viewforum.php?f=49
Old Oct 23, 2007
Balut Eating Champ
yes, the RCA connections are connected correctly and all fuses are checked on the amp, under the hood and inside the car, all fuses are GOOD...
i can hear the distinct noise on the subwoofers as i turn on the power... but when i play the radio or cd it doesn't emit any sound to the subs... the speakers in the car works...
Old Oct 23, 2007
FGCOUPE's Avatar
fault in patch cord(s)
fault in headunit from patch cord(s)
fault in amplifers rca input
could be many thing my friend, could even be easier then the eye can see....
Old Oct 23, 2007
Balut Eating Champ
my set was working fine for about 3yrs now and it died yesterday... but i will triple check all connections tomorrow and we'll see what it is...
PLAN B:
i'll buy an amp at bestbuy tomorrow and see if that works... if it does... then it's the amp if it doesn't then it's the wiring...
Old Oct 23, 2007
FGCOUPE's Avatar
i just added this section first "NO AUDIO" to my forums, check it out ...
im adding as we speak too.....
Old Oct 23, 2007
Balut Eating Champ
great info bro... thanks, but if all else fails, i will just buy an amp from walmart then i will return them if it doesn't work hehehe man i love customer satisfaction crap
Old Oct 23, 2007
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
12V on amp turn on wire?
Disconnect the subs from the amp and take a resistance reading. If you have a 9V battery you can pop the subs when they're unhooked and see what it sounds like. Any scratching noises or just a thump?
Old Oct 23, 2007
Balut Eating Champ
let me try that right now...
Old Oct 23, 2007
Balut Eating Champ
it makes that thump noise... the same noise i hear when i turn on my car...
Old Oct 23, 2007
Sounds like the subs are good. Bench testing or swapping out the amp seems like a good next step.
Old Oct 24, 2007
FGCOUPE's Avatar
i have a cadence z1000 if you want it?
but itll prob be chaeper for you to buy one where you live?
Old Oct 24, 2007
Balut Eating Champ
thanks for the offer bro... the thing about it is, just in case the new amp doesn't work either if connected then i will have two amps and i'm currently in canada right now which it sucks... i mean CANADA doesn't suck, but the situation that i'm in
i haven't had a chance to go to bestbuy today, so i guess i will try again tomorrow...
Old Oct 24, 2007
FGCOUPE's Avatar
not a prob bud'
but im lost here...
are you visiting Canada?
cuz in you Loc it says LosVegas?
Old Oct 24, 2007
FGCOUPE's Avatar
ive added this new info onto my site. Ive given the credits to christmas pie for his advice.
Old Oct 24, 2007
Balut Eating Champ
Originally Posted by FGCOUPE
not a prob bud'
but im lost here...
YEAH, i drove about 30hrs to get here, and it sucks when your sound system doesn't have the UMPH!
Old Nov 6, 2007
Balut Eating Champ
yup the amp was fried like a damn KFC!!! ( thanks for the help guys!!!
close please!!!
Tedverseti
Apr 23, 2020 01:45 PM
UltraHDGames
Jun 8, 2016 05:16 PM
ricer_em2
May 11, 2016 08:09 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
metalpres
Sep 23, 2015 05:22 AM
