HID kit problem
Technical Assistant
HID kit problem
Got my Tenon HID kit in today, and plugged it all up. Low beam doesnt work but the high beam doesnt, and I tried to put in a 20a fuse instead of a 15a still nothing. Here is the bulb
The little guy on the left is my high beam
The big guy on the right is the xenon low beam
there is also a glare shield on the bottom of the xenon bulb (nice feature i think)
plugged up all of the ballasts, etc.etc. and still nothing. The only thing feeding power to the bulb/ballast is the stock plug, the kit didnt come with any kinda relay harness...what the hell is going on here. There is no humming or any sound coming from the ballasts, and the little High beam still works.
That might have been confusing so here goes simple. Low beam doesnt work, high beam does. Ballast doesnt seem to be turning on
Technical Assistant
Re: HID kit problem
I dont think there is any way to have them wired wrong because the clips only fit into 1 other clip...no the highs dont make any kind of sound either. i dont have a relay harness/w.e it is but i was told its not neccesary to make the kit work
Re: HID kit problem
also, our car's wires aren't designed to handle the high current draw of the ballasts during startup. so, no, you don't HAVE to have a harness to make them work, but it's a lot safer for your car. if you want to risk burning up your wires over time, then don't use a harness. if you're smart though, you'll spend $20 or so on a relay harness.
Technical Assistant
Re: HID kit problem
do you have a 7th gen? if so, you do know that the headlights are ground switched (2 grounds, common positive)? are you sure you're tapped into the car's harness correctly? if so, you'll need to accurately describe every single connection you made before we can help you any more. pics of each connection would be better.
Here is how I plugged everything up. There are 4 plugs on the end of the bulb and 2 on the end of the ballast.
the one thick wire splits into 2 and hooks up to 2 wires coming from the bulb
one wire from the xenon bulb goes back to the ballast
one wire from the xenon bulb has a clip on it that hooks up to the stock harness
other than that I didnt do anything else. Here is the kit itself
Re: HID kit problem
Yes I have a 2001 honda civic lx sedan. No I didnt know anything about grounding I thought it was a Plug and Play kit so I plugged everything up, and didnt think there was any other wiring I would need to do. I am thinking about returning the kit because I cant seem to figure out a way to get the headlight to seal properly in the back...the bottom of the bulb isnt round to accept the shape of the rubber cover il try to figure out something. Where can I get a relay harness for 20 dollars??
Technical Assistant
Re: HID kit problem
it's hard to see from the pics, but it appears that there's 2 red and 1 black on the H4 connectors. if that's the case, then you kit is set up for positive switched H4 and not negative switched H4 (which you have). there needs to be 1 red and 2 black. they gave you the wrong kit. the halogen high beam doesn't care about polarity, but the ballasts do. the ballasts have to have the proper polarity or they won't work. can you verify how your kit is wired?
http://entertainment.webshots.com/album/560591127epTuEq
Let me know thanks for all of your help
you can view all of the pictures fullsize for detail
since its reversed cant I just flip the plug that goes into the ballast...would that even everything out??
Re: HID kit problem
So whats my best move with this kit?? Here are some more pictures of all of the plugs and how I had it all wired up
where the black is should be red, and the 2 reds should be black. that would give you proper polarity to match up with our cars. it's up to you what you want to do. you could just change the polarity of the power wires going into the ballast and it should work fine. or send it back and tell them to get their act together.
Technical Assistant
Re: HID kit problem
in this pic here:
Technical Assistant
Re: HID kit problem
So in other words just plug the plug up the reverse way to the ballast? I thought about doing that but didnt want to harm anything
EDIT: just tried it and everything works. Now I just need to figure out how to get the rear to seal I may just use a lot of tape to seal it up. Rep to you, and thanks a lot
Re: HID kit problem
you'd either have to de-pin it and switch the wires, or cut and splice them in reverse. that plug that goes into the ballast has a tab to prevent it from being reversed. also, if you've plugged the ballasts in backwards, you likely blew a power fuse. that happened to me when i was trying to test my HID fogs and hooked the ballasts up backwards. the car's fuse blew.
Technical Assistant
Re: HID kit problem
Re: HID kit problem
https://www.civicforums.com/forums/advertise.php
Re: HID kit problem
Hi guys Im from Argentina this is my first post! i´m having the same problem going on with my HID install. Y have an H4-2 Kit with a double black wire, a single black and a red. The HID starts great, but when I want to use the Hi beam, it doesn´t start and the xenon flashes like crazy!!.
I think i have a negatively switched system. My hi beam signal stays on my dashboard when xenon (lo) is on!!
This is a pic of my bulbs:
I read that Electric130 exlained that I have to de-pin and invert the wires, but im a newie with this and i really dont know which wires do i have to invert to make it work!!!. Here´s a pic posted by ultimatetuner10.
Which wires do I have to invert? Green Arrow / Orange Arrow? OR MAY BE OTHER??
Thanks in advance!!!
Re: HID kit problem
The bulb I´ve got is a H4-2 (hi halogen/lo xenon).
Thanks!
Re: HID kit problem
Rogelio Rey
May 24, 2015 08:30 PM
Youshoe
May 22, 2015 09:36 PM
JohnnyBxo
16
May 9, 2015 05:53 PM
