An issue with Foglights ! (fuse)
Old Aug 20, 2007
mani_is_kool's Avatar
mani_is_kool is just really nicemani_is_kool is just really nicemani_is_kool is just really nicemani_is_kool is just really nice
Ok I did the search and didnt find too much of infor on this one.
All of us that have bought Fog Lights from EBAY have had one or another issue related to something. My problem used to be the fuse. 5 minutes after Installation my fogs stopped working and I came on the forums and searched and asked people and they told me that the FUSE that comes with the EBAY FOgs are cheap ones. So I went to AUTOZONE and got meself a little box of fuses and replaced it with a 15amp one. now 6 months it was fine .. last week my fogs stopped working again. I went under the harness stuff and found the same kind of MELTED FUSE.
What can be done to avoid this in future? put a 20amp fuse ? or what ?
Old Aug 20, 2007
dalaw's Avatar
Bone Stock!
Re: An issue with Foglights ! (fuse)
i guess you can just replace it every 6 months? Mine melted about 2 years ago and it still fine now. I replaced it with the same amp
Old Aug 20, 2007
2k1civic01's Avatar
2k1civic01 is just really nice2k1civic01 is just really nice2k1civic01 is just really nice2k1civic01 is just really nice
mine does the same thing. but now I'm lucky the fuse will hold up for a whole day.
Old Aug 20, 2007
So thats a NO for using a higher amp FUSE ?
Old Aug 22, 2007
electric130's Avatar
not unless you either want to replace all the wiring with bigger wires or set your car on fire. your choice.
Old Aug 22, 2007
Ahhh I wish u could be a little more clear in what u said coz now u got me confused so Just stick with th 15amp fuses ? YES or NO???
Old Aug 22, 2007
uh 15 amp is really high, youre trying to cover up the problem, and thats gonna = car on fire as mentioned above. whats the stock headlight fuse, like 7.5 amp? you need to fix the problem which is the fog light harness, not the fuse. if the fuse is blowing, its because somethings wrong.
Old Aug 23, 2007
yes. 55w/12v=4.58A so bare minimum to run 2-55w bulbs, you need a 10a. however, if you have a 15A fuse then you need to make sure the wires are at least 18ga, but 16ga would be better.
Old Aug 23, 2007
uh guys ... but the foglights came with the 15amp fuse in the first place... i just replaced the ebay fuse (which was 15amp also and lasted like 2 minutes) with an Autozone fuse. Anyone else over here who bought Yellow fogs from Ebay specifically by seller TRENDGEAR can easily verify it. And I did post to ask what might be wrong when the fuse went bad on the first day and members here told me to replace it with a good autozone fuse coz the ebay fuses suck in quality ...
Old Aug 23, 2007
rick1574's Avatar
rick1574 will become famous soon enough
are you grounding out somewhere? do you have exposed wire anywhere in your harness?
Old Aug 23, 2007
ESK1k20A2's Avatar
ESK1k20A2 will become famous soon enough
Do a load test
TiggerDX
Jun 18, 2015 01:43 PM
intensity
May 12, 2015 10:43 PM
CiViCPrAnInG2k1
Mar 4, 2002 10:06 AM
eskimo
Feb 8, 2002 02:42 PM
Professional
Jan 29, 2002 07:17 PM
