How to seal the trunk
Hey guys,
Now that i put my subs in, my trunck rattles like a bitch, i know i could use dynomat, but i want something more proffesional, any suggestions on that.
Thanks
Super Sajin
Thanks
Super Sajin
for one a Mistake almost everyone makes it's not DynOmat it's DynAmat..and no RAAM Mat is alot better for the price.. Also..al you have to do really is tighten your lecense plate bolts.. and tighten the trunk latch and you're pretty much set
mohawkboom,
What if i got it sealed by a car audio shop, they use some find of spray over all the parts in my trunck, i think it's like $70 to do it. do you think it's worth the money?
Super Sajin
Super Sajin
You need to take everything out of the trunk, even the carpet. Get it down to the metal. Then use foam (expandable and non expandable). Spray the expandable in all the cracks, but not too much because it will buckle the bodywork. Use the non expandable in the trunk lid, but be carefull not to do too much. You can allways go back and spray more. For the best results, use the dynamat on all the metal that you can get to. And use an under body spray under the trunk. If you do it correctly, it should cost about $100 or so. And if a car audio place does it, it should cost about $500 for a good job. If you dont like the foam idea, go and get insulation for your house, I think B13 is the best. Not too sure if it is called "B13." But its a medium texture insulation. Put it everywhere. Dynamat and foam will take care of the problem. E-mail me if you have and questions.
<< You need to take everything out of the trunk, even the carpet. Get it down to the metal. Then use foam (expandable and non expandable). Spray the expandable in all the cracks, but not too much because it will buckle the bodywork. Use the non expandable in the trunk lid, but be carefull not to do too much. You can allways go back and spray more. For the best results, use the dynamat on all the metal that you can get to. And use an under body spray under the trunk. If you do it correctly, it should cost about $100 or so. And if a car audio place does it, it should cost about $500 for a good job. If you dont like the foam idea, go and get insulation for your house, I think B13 is the best. Not too sure if it is called "B13." But its a medium texture insulation. Put it everywhere. Dynamat and foam will take care of the problem. E-mail me if you have and questions. >>
All that but most of it is unnecessary...Just tighten the trunk bolt and your set unless your running some high SPl...and also don't use Dynamat it's good..but it's WAY WAY WAY overpriced.. Use RAAMmat.. at $79 for 62.5sq.ft and it's as good as Dynamat Extreme you can't go wrong.. Dynamat Extreme costs over $200 for 36sq.ft.. do the math [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
I Only push it because it's great and it's Dirt cheap..even compared to dirt cheap next to useless deadeners.. It's cheaper than most..and it happens to be one of the best deadeners on the market.. so forgive me if I'm Trying to find people a great Deal.. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
(quietly asks my sponsors if that post sounded good).
Umm yeah [IMG]i/expressions/face-icon-small-smile.gif[/IMG]..
Cheers
Mohawk
And no I'm not sponsored in any way.. I don't even use Raam mat
Cheers
Mohawk
It's not unnecessary if you are going to have some serious bass. The stuff I build needs it all. Then again, I do go a little crazy, BUT I don't have ANY rattles. It all depends on what you have in your car, and how funny you are about getting them ALL out.
Hey Mohawk. Want to tell me about this trunk latch tightening. My trunk rattles like hell. lol and I'm an idiot and just did nothing about it. but if i can easily tighten this latch. I'm game to do it right this second.......
Nighthawke.. The black plastic piece on the bottom part of your trunk. Where you see a black rectangle shaped latch. (where the truk lid latch hooks onto) There.. just pry off the black plastic, remove it it's just clips.. Lossen the 2 bolts on the hook(well it's a rectangle) and lower it down about 3-4mm close the trunk.. crank your subs.. see it the rttling has stopped.. if not.. tighten it a big more..once it's good.. put the black plastic piece back on. The whoe process taes about 8 minutes [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Cheers
Mohawk
Cheers
Mohawk
Crazygrlinak
Oct 8, 2015 05:06 PM
Munzy
21
Oct 7, 2015 07:48 AM
Sep 27, 2015 11:33 AM
