Fog Lights +OEM LIP
Diamond Member
Fog Lights +OEM LIP
Im am planning on buying some eBay fogs, but i have a OEM lip kit (not aero). i searched and found out you can install, but i was wondering if i will need to detach the lip from the bumper, and if so, how difficult it will be to put back on. Thanks!
I wil fix vBPlaza today
Re: Fog Lights +OEM LIP
You could prolly get away with the cutting of your bumper with your lip still on, i dont see where it would get in the way. Besides doesn't the front lip have 3M adhesive tape on the inside as well as the screws holding it on?
That is all that holds mine on. The two screws in the wheel well and then three under the bottom that are small and hard to see along with the 3m tape across the front. If you are careful you will not have to remove the lip but it is recomended.
Diamond Member
bump
anyway i have a 02 EX and im going to buy a ebay kit. I really DONT want to replace my cruise control (you can never have enough buttons!!) so is there any way i can rig the button to fit in by the 12v?
