New speaker time
Old May 18, 2007
half_n_half17's Avatar
half_n_half17 is an unknown quantity at this point
New speaker time
It's been a while since I paid any attention to car audio, but now it's time for me to replace the speakers in my car and I need some suggestions. I'm looking for a pair of 6.5" and I don't want a sub so i'm looking for speakers that have some a decent amount of bass. They're going to be amped with about 80w each and I'm looking to spend in the neighborhood of $100. I hate harsh sounding speakers and would much rather have a speaker that is more forgiving in the high frequencies. Any help would be greatly appreciated!
Old May 18, 2007
snobird's Avatar
snobird is an unknown quantity at this point
Re: New speaker time
i just installed 4 6.5 polk db component speakers. sounds great i have the 4 tweeters mounted niceley and the speakers are nice too.
they ran me $149 per set msrp is $199 a set so do some shopping but the polk db component is the way to go
Old May 19, 2007
JMUCivic03's Avatar
JMUCivic03 is an unknown quantity at this point
Its going to be tough to get any kind of good bass if you go with components all around. Most manufactuers who make components figure that if you are spending the money on components and are willing to mount tweeters etc, then you probably care enough about sound to get a sub. For this reason, they keep their speakers from producing the lower end of the sound spectrum and components usually only dip down to like 50 or 60Hz, with very little output in that range. The only small midrange speakers that I have ever seen truly reproduce the audible lower end of the freq range (down to low 20Hz in room) where the adire extremis, which arent on the market anymore. You could always purchase some other midbass speakers for the rear deck or even some 6.5" subs like the new JL w3 that are coming out in july, but you would have to build little .25ft enclosures for em. Otherwise, like I said, most aftermarket speakers are meant to be accompanied by a sub to faithfuly reproduce more of the sound spectrum. As far as "harsh" sounds in the upper spectrum, I would avoind anything with a metallic tweeter....go with silk if possible. Some people will go on for hours about the benifits of one over the other but it is complelty a judgment call....I myself prefer titanium tweets. Some good speakers with soft teewts to look into would be JLs or infinitys.
Old May 19, 2007
snobird's Avatar
i have the polk silk tweets they sound amazing but get u at least one 12 inch sub and some nice speakers and you will be good
Old May 19, 2007
Thanks for the help, I ordered the DB 650's. Crutchfield has em for $60 and I found a free shipping code.
Old May 20, 2007
ryox82's Avatar
ryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to all
I just put in db650's too. Could not get them mounted in the rear so I used sonys that filly out the bottom end a bit better. Once I deaden everything I might not even need a sub for a while. As a note, in order to fit the db650's with crutchfields provided spacer I had to cut the circle on the door that meets the stock speaker. A razor knife made quick work of it. Make sure all panels are resecured properly as my setup unamped is enough to rattle the crap out of the car. This is by design on my part as I am waiting for my rolls of rammat and ensolite to come out of back order and plan on tearing it down again anyways.
Old May 20, 2007
electric130's Avatar
what's the code?
Old May 20, 2007
Free shipping: PA145
Old May 20, 2007
i have some infinity 6.5 amped 30w and boy they can pound. i think youll be happy with what you got, but remember you cant just throw in speakers and expect good sound. the deck doesnt matter much either, i run a cheap under $200 alpine, their second to lowest model. its the install that will mean everything. and you prolly should get separate tweeters too and just run them off the deck power if youre amping all the speakers already. then sound deadening will be your friend. do a layer at least in the front doors and the rear deck. make sure the front speakers are sealed up good.
Old May 20, 2007
DsevenEm2's Avatar
This is Myspace
u shouldve got one of those intercom megaphone things that stick out on the side of the building. the best ....bang for ur buck? lol, those things are cool.
Old May 20, 2007
snobird's Avatar
i ahve the db6501 the compnent set with seperate tweeters it makes a hell of a difference
Old May 21, 2007
is there an echo in here?
Old May 21, 2007
ryox82's Avatar
I know two slim shady wannabes that ride up and down the streets around here in a POS car that have those blastin the most gangsta ****....its really funny.
Old May 21, 2007
Don't hate... people respect me when I use the megaphone.
Old May 21, 2007
ryox82's Avatar
hahahahahhahhaha! Well to each their own...im more about in cabin sound quality. I don't care if people can hear my music outside my ride....if done right they wont be able to hear much unless I roll down a window or open a door.
Old May 21, 2007
yeah with my doors and windows closed and the volume turned way up, i can barely hear anything from outside. that means you have a good install.
Old May 22, 2007
wanna come do mine? i pay in 12-packs!
Old May 22, 2007
ryox82's Avatar
lol it isnt that bad electric. Alot of people say it takes forever to do but really that all depends on the experience of the installer. I think I did my girls rear deck in only like 5 minutes if that. Doors are easy as well if you can manage working with large enough peices. I havnt worked with ensolite yet so I can't comment on that. Im goin crazy waiting for my matting because I wanna do my car now lol. Just a little bit in my girls car made a HUGE difference
Old May 22, 2007
i've done it before, i just don't want the hassle of doing a whole bunch. i can do HU's, amps, subs, speakers, whatever. i like all that. i just don't like the whole dynamat crap.
Old May 22, 2007
ryox82's Avatar
Eh for me its just another project, like building a computer, or a model or something. Just keeps me occupied and I can enjoy the end result every day considering I drive a total of 2 hours or more back and forth to work every day. Now...amplifiers...thats uncharted territory for me...I have read up on how to route the power cables, I just don't know how to wire the speakers
Old May 22, 2007
Wiring the speakers is pretty easy. You just have to remember to keep the speaker wires away from the power wires as much as possible. I routed the power down the passenger side and the wires down the middle next to the parking brake. As for the deadening I've got some asphalt based stuff in there now, which makes a huge difference. If I had to do it over I would've picked a butyl based mat cuz my car STANK for a good 6 months after the install.
mistermenphis22
Apr 3, 2016 08:06 AM
WLakers
May 4, 2015 06:23 PM
cheekyvirgin
Bluetooth
Apr 27, 2015 05:31 AM
SilverCivicCoupe68
Nov 30, 2001 02:34 PM
supercivic01
South
Nov 30, 2001 11:27 AM
