I bought a HO Alternator For A 01-03 ACURA EL and it says it fits HONDA Civic 01-04
Old Apr 24, 2007
rdzlyz's Avatar
rdzlyz is on a distinguished road
well i recently bought this
http://cgi.ebay.com/ebaymotors/ws/eB...6744764&rd=1,1
in the page it says it replaces p#A5TA7091 alternator and it also says in the description that it fits all civics from 2001-2004 that has 1.7l engine.
AM I OK?
Old Apr 24, 2007
sl33pyriceboi's Avatar
Re: I bought a HO Alternator For A 01-03 ACURA EL and it says it fits HONDA Civic 01-
well, get it professionally put in......and tell us.....
then you'll be out hero...
Old Apr 24, 2007
electric130's Avatar
you should be fine since the EL is just an overpriced civic.
Old Apr 24, 2007
lxcivic2k1's Avatar
^^ yea the EL is just the acura version of the civic in Canada and places like that.
Old Apr 24, 2007
rdzlyz's Avatar
as it says on the description it says it replaces p#A5TA7091ZC which it is my p# on my alternator on my civic so im good...i hope
Old Apr 24, 2007
mugenman's Avatar
"mmmBAHHHH" - vtec y0
yeah youll be good if its the same part # then you will be fine
Old Apr 24, 2007
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
post pics when you're done. i think i'm gonna need a bigger alti when i upgrade to 12s....also, would it require a different belt since the pulley is smaller? or is there enough adjustment with the stock belt to cover it?
Old Apr 24, 2007
if the pulley's different, it should come with a belt. i've read that the alterstart alternators come with a belt and a 4ga power harness.
Old Apr 24, 2007
Physpher's Avatar
Physpher is an unknown quantity at this point
mine didnt... my voltage drops under about 12k but then it shoots up to 14.8v. also it squeeks. sometimes loud, sometimes not. i need a new belt
Old Apr 25, 2007
rdzlyz's Avatar
ill take pictures when im done putting it in...right now im waiting for it to come int he mail
Old Apr 30, 2007
rdzlyz's Avatar
it fits, it actually fits, i had the shop install it since i didnt have anytime in installing it.
so far the alternator is working well on my end. Im running a Alpine CDA-9883 w/ Kicker ZX850.2 Amp, Two Alpine Type-R 12" subs and let me tell u its great. I have readings from 13.5v and up when bass hits real hard then it goes right back up to 14v depending if the car is idle or reving
Old Apr 30, 2007
good deal bro. i just looked over that auction and it says:
"A four gauge power output cable is required for proper battery maintenance."
if it didn't come with one, you better buy some 4ga cable and run it quick unless you already have. you'll quickly exceed the capacity of the stock 8ga cable and could create a dangerous situation with the alternator putting out that much.
Old Apr 30, 2007
rdzlyz's Avatar
i have one question....i know i have to buy one quick but, where do i put it on the alternator, i know there is the 4p connector which is a regulator and there is another one....
Old Apr 30, 2007
rdzlyz's Avatar
Ok here is a picture of my alternator rewired.
http://www.indabay.com/rdzlyz/2/170898475525.jpg
i have the stock 8ga and the new 4ga(redwire) on the alternator to the battery. will my car be ok with both of them installed.
and also the 4ga you see a silver metal on it should i tape that because it does get hot right or i dunno.
also heres the wires hooked up on my battery
http://www.indabay.com/rdzlyz/2/170898438661.jpg
Old Apr 30, 2007
use heat shrink, not tape. and you don't need the stock wires. you won't exceed the 4ga wires, so just use them.
Old Apr 30, 2007
rdzlyz's Avatar
well I do know I don't need the stock wire but I'm just saying. would it be ok just to leave them on there becuz I don't want to have ne trouble of taking everything apart again?
and ok ok ill use heat shrink instead of tape. ill go on and get that tomorow
Old Apr 30, 2007
i don't think it will cause any problems to leave it, but i'm not positive. i don't know what all is in that harness that you may/may not need.
Old Apr 30, 2007
rdzlyz's Avatar
all I did was add the 4ga wire to the alternator and hooked it up on the positive post on the battery. that was it actually
Pr0n1s
Apr 30, 2015 03:08 PM
jessicakaybby
Apr 20, 2015 12:11 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
BreezeNine
Apr 14, 2015 05:41 PM
bahena08
Apr 11, 2015 05:09 PM
