04 ex cluster into an 02 ex
Old Apr 21, 2007
DieMaster's Avatar
DieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of lightDieMaster is a glorious beacon of light
i searched and it said this was a direct swap. if not what do i need to do it wire it up? i know the green plug wont reach. i need the pinouts for both plugs.
Old Apr 21, 2007
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Re: 04 ex cluster into an 02 ex
Use The Search Button Again! Look For The Diy!
Old Apr 21, 2007
TRIZ's Avatar
ibtl
Old Apr 21, 2007
DieMaster's Avatar
why are u saying it' going to be locked. i have a legit queston.
are the EX clusters plug and play? evreyone says there diffrent than the others and the others u have to rewire. i'm confused now.
oh and i DO NOT want to de-pin my existing harness. i'd rather make a adapter for the new cluster.
Old Apr 21, 2007
you need to rewire it. if you dont want to repin the connectors, find a junkyard, cut off the harness wires, and have fun splicing.
Old Apr 21, 2007
kingofheartz's Avatar
kingofheartz will become famous soon enoughkingofheartz will become famous soon enough
https://www.civicforums.com/forums/4...faq-video.html
Old Apr 21, 2007
DieMaster's Avatar
ok thanks gearbox thats what i was confused about.
Old Apr 21, 2007
jason_hann53's Avatar
jason_hann53 is an unknown quantity at this point
its not gunna work man. the connections on the top of the cluster are differnt in an 04 thne in an 02. i put an 01 ex cluster in my 02 DX, cuz it had the tach, and everything just plugged in and worked
fatih717171
Jul 25, 2016 06:22 PM
hondacivic0253
Sep 29, 2015 08:06 AM
260000milesgoal
Sep 25, 2015 07:41 PM
rayman009
Sep 12, 2015 08:30 PM
Bricoleur
Sep 9, 2015 12:23 PM
