Headlights "Flicker"
Old Apr 8, 2007
Viper42391's Avatar
Viper42391 is an unknown quantity at this point
Hello everyone!
I have a '97 Dx. When driving at night, with the headlights on, the lights dim and get brighter, over and over... it seems that the battery isn't giving off enough power, and causing them to dim, then get brighter, dim, get brighter... Anyone else experience this? How can it be solved?
Thanks!
Old Apr 9, 2007
msickler4's Avatar
msickler4 is an unknown quantity at this point
Re: Headlights "Flicker"
i have a 97 civic dx as well and my headlights flicker. i thought it could be the ground wire but i dont know. maybe a short somewhere.
any help would be great!
Old Apr 9, 2007
Viper42391's Avatar
I am guessing this isn't just my car's problem. I have found a few articles online that describe the same thing, but nobody knows how to stop it. Hopefully I will be able to find the source of the problem when I start driving it at the end of this month. Maybe someone knows how to solve this?
Thanks
Old Apr 9, 2007
twinbo's Avatar
twinbo is an unknown quantity at this point
I don't know much about your model but I know 7th gen alternators are weak. If you are running any kind of stereo this happens at high load. Maybe get your alternator checked out.
Old Apr 9, 2007
Viper42391's Avatar
Allright... Thanks for the insight. I am only running the stock stereo, not loud (I don't like loud stereos) I will check that out when i check out my battery. Thanks!
Old Apr 9, 2007
Physpher's Avatar
Physpher is an unknown quantity at this point
yeah, it will do it when your fans come one, ac, stereo (even factory) and turnsignals... i upgraded my alt and battery and it doesnt happen anymore.
Old Apr 9, 2007
Viper42391's Avatar
Thanks for the reply and a possible solution. If you don't mind me asking, what brand of alt. and battery are you using now? That will be one thing I would do after I get new clear headlights to keep them steady.
Thanks!
Old Apr 9, 2007
pon55's Avatar
The rules of auto electronics= good ground and connections. Take your time (and a cheap voltmeter) to check all grounds . Check and clean all connections and fuses. A 10 year old car build a lot of corrison(sp) on electrical connections.
Old Jun 16, 2012
texasbootboy's Avatar
texasbootboy is an unknown quantity at this point
http://www.tegger.com/hondafaq/tsb/civic/x99-029e.pdf
meicalnissyen
Sep 25, 2015 12:12 AM
rnaodm
Sep 21, 2015 12:42 PM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
