CD Player Will Not Power On!!!!!!
Old Mar 27, 2007
parmo's Avatar
parmo is an unknown quantity at this point
Hey there guys, my stock cd player is able to load and eject cd's however it will not power on. I installed another aftermarket deck thinking that there may be a problem with my stock deck, however this did not solve the problem as the aftermarket deck to did not power on. Could it be that one of the wires short-circuted and if so is there any way that I can confirm that this is the problem? if so how can I correct the problem and get my deck working again? Input appreciated
Thanks
Old Mar 27, 2007
sl33pyriceboi's Avatar
Re: CD Player Will Not Power On!!!!!!
check ur fuse.
Old Mar 27, 2007
BlueCivic04's Avatar
BlueCivic04 is an unknown quantity at this point
check ur fuse.
are all the fuses in the engine? which one is it?
Old Mar 27, 2007
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
Have you looked at Fuse #8 (7.5A) in the underdash fuse box?
Old Mar 27, 2007
check owners manual for fuse list. they are under the hood next to battery and also under the dash above brake pedal .
Old Mar 29, 2007
05reverb's Avatar
05reverb is an unknown quantity at this point
x2
and if that fuse is good, then check behind your headunit, the red wire should have power when ignition is in acc. or on position, if not, check the white/red wire at your ignition switch for the same thing. if there is no problem there, check the #9 (10 amp) fuse under the hood and the yellow wire in the back of your headunit for constant power nomatter ignition position
jordan1794
General 8th & 9th Gen
May 11, 2019 08:59 PM
Dave1984
Jul 22, 2015 06:10 PM
breanna_17
Jul 21, 2015 04:01 PM
