Need help. Electrical question
Old Mar 23, 2007
gameboi499's Avatar
gameboi499 is an unknown quantity at this point
I want to install a glow stick onto my sub box. I want to know if it's ok to connect the power/ground wires of the glow stick to the power/ground wires of the amp. Will this cause a short circuit? Do I need to find a different power source or will the one from the amp is ok?
Old Mar 23, 2007
_unclejuice's Avatar
_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough
Re: Need help. Electrical question
the power from the amp is fine. just fuse the neon or whatever youre hooking up and it will be ok.
Old Mar 29, 2007
05reverb's Avatar
05reverb is an unknown quantity at this point
it's ok if you want it to always have power, is the stick like a neon? if so you would only want it on when the trunk is open or anytime the amp is on? if so, you could use a relay and either use the remote wire(to be powered anytime the amp is on) or the trunk light positive wire (to have it turn on when you open up the trunk)
thana
Jun 15, 2020 07:05 PM
steveneddy
May 19, 2015 02:39 PM
superstanko
Apr 28, 2015 04:38 AM
viper775
Dec 9, 2001 10:52 PM
BeefMan
Nov 25, 2001 10:38 PM
