ex cd player in lx
Old Mar 21, 2007
jitb's Avatar
jitb is an unknown quantity at this point
ex cd player in lx
my gf has a lx it didnt come with a cd player just tape/amfm, i was about to get a ex cd player form a guy on here im trying to make sure i wouldnt need any extra wiring for it. And make sure its plug and play like i think it is.
Old Mar 21, 2007
BlueCivic04's Avatar
BlueCivic04 is an unknown quantity at this point
Re: ex cd player in lx
they are all the same. all you need to do is get the wire harness and trim kit that works with your specific car. go to best buy or some place like that and ask for a wire harness and trim kit for your year/make/model car. should be no more than 20-25 dollars.
Old Mar 21, 2007
CraigW's Avatar
If everything is original...? It should be 100% plug and pray. Both units are single DIN and the wiring is the same. Unless you are talking SE double DIN.
Don't forget to get the code from seller.
Old Mar 21, 2007
jitb's Avatar
alright, cool ill make sure i get the code.
Old Mar 21, 2007
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
Agreed (except you may have meant play.)
Only likely issue is if hers is a coupe and the other was a sedan, nothing that can't be dealt with though.
Old Mar 21, 2007
CraigW's Avatar
No No, "Plug and Pray" like Microsoft.
I imagine the cassette and the CD units are the same size (single DIN) It should work fine IMO.
Old Mar 21, 2007
Cool, that's why I said may, I wasn't sure.
Sedan doesn't have turn on wire for antenna amplifier, the coupe does. Just check the AM/FM reception once you're done.
Old Mar 21, 2007
jitb's Avatar
so if i get it out of a sedan what will i need? to get the antenna amplifier working.
Old Mar 21, 2007
Tap accessory power (yellow/red) over to the antenna turn on wire (yellow/green).
Old Mar 21, 2007
Taffy's Avatar
Taffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant futureTaffy has a brilliant future
"Plug and Pray"...
Haha, I like that...I'm gonna use that.
Old Apr 1, 2007
Scott Civic's Avatar
Racism sucks, just like your Mom...
Scott Civic is a glorious beacon of lightScott Civic is a glorious beacon of lightScott Civic is a glorious beacon of lightScott Civic is a glorious beacon of lightScott Civic is a glorious beacon of lightScott Civic is a glorious beacon of light
Out of curiosity, why did the coupe have the amplifier and the sedan didn't?
Old Apr 1, 2007
TRIZ's Avatar
^because the em2s rock and the es1's are ennnhs, lol. Good question.
Old Apr 1, 2007
Looks like the coupe uses two separate antennas in the rear glass.
File Type: pdf
File Type: pdf
Old Apr 1, 2007
Hmm. That may be so, but, still, why would they deem it necessary to not put it into a sedan? Did they think that two extra door handles would boost reception?
Old Apr 1, 2007
Haha, I think you're gonna have to talk to someone at Honda for any further explanation.
lolhowell
Photography & Videography
Sep 11, 2015 05:09 PM
