speaker mounting kits?
Old Mar 21, 2007
yingjai's Avatar
yingjai is an unknown quantity at this point
i replaced my oem speakers with 6.5" boston acoustics. they came with "mounting hardware" which consists of screws and clips. the instruction sheet for mounting is generic and the hole in our doors are not big enough to be mounted like in the picture.
are there mounting kits for aftermarket speakers anywhere? i searched and only came up with headunit kits. other possible mounting solutions i found and am trying to avoid are drilling into the door, cutting the door to make hole bigger, and destroying oem speakers to get the bracket.
how did you guys install ur speakers?
Old Mar 21, 2007
BlueCivic04's Avatar
BlueCivic04 is an unknown quantity at this point
Re: speaker mounting kits?
http://www.sounddomain.com
look for speaker acessories. They have all kinds of things that might work for you, including speaker mounts.
Old Mar 21, 2007
electric130's Avatar
dude, read my DIY sticky. it's in my sig. i tell you how to make mounting spacers and how to mount them. i've got an extra set if you want them cheap. if not, follow the directions and make your own.
Old Mar 21, 2007
yingjai's Avatar
Like I said, I'm trying to avoid drilling into my door and your diy does just that.
Would this fit on my 04 coupe? and I don't need to drill right?
http://www.cardomain.com/item/SCOSAH6
Old Mar 21, 2007
you'll still need to drill with those. if you have looked at the stock speakers, you know they have 2 tabs at the bottom and a clip at the top. those adapters don't have that. they have 3 tabs with holes to put screws in. i honestly don't think there's a way to avoid drilling holes that will give you decent results
Old Mar 21, 2007
yingjai's Avatar
i guess i gotta do what i gotta do.
Ray Darvi
Aug 12, 2015 11:55 AM
WaryDriver
Aug 8, 2015 05:08 PM
Nalmonte
Jul 22, 2015 09:08 AM
671civicLX
Jul 9, 2015 03:22 PM
