Problem loading CD with SE/Reverb 6 disc unit
Old Feb 11, 2007
k-man's Avatar
k-man is an unknown quantity at this point
Hey Guys,
I just got my SE 6 disc unit the other day and I installed it yesterday. Everything works great with one exeption.
If i try to load CD's, I press the load button and all it does is flash "busy" and blink the red light and nothing happens. All other functions work great (radio, aux) but for some reason i cant figure out what is going on with the CD loading.
It would be helpful if i had the instructions for the deck to possibly trouble shoot but i dont have them as they are part of the owners manual.
I beleive the unit just may need to be re-set, but i dont see a reset button on the unit itself. I have tried unplugging the unit and that didnt work either.
Any ideas? anyone have this problem? or if someone with a EX/LX SE or reverb could look in their manual for me and hopefully shed some light on this. What is the proper procedure for loading anyway? press load and it should accept cd's right away, correct?
thanks!
Old Feb 11, 2007
you need to reset it, are you sure there no tiny button on the front, like something you need a pen to push? every radio needs to be reset once installed (even aftermarket) or things work wrong. have you tried holding the eject button, a big pic of the face would help.
Old Feb 11, 2007
k-man's Avatar
hey, thanks alot for the reply.
The deck is just the regular SE Cd changer, a pic of one is in this thread:
https://www.civicforums.com/forums/3...-properly.html
the guy posting that thread actually had the same problem that i am having. You are right though, most have a reset button though i dont see one on this deck. I did try holding the eject and load buttons, didnt really do anything....
any more ideas?
thanks
Old Feb 11, 2007
so this is the one that you can stuff 6 cds in and change between them? did you put any disc in already? i guess i dont understand what problem is. is the eject not giving you the cd back? or are you putting one in and you cant load anymore, cause you have to wait for it to load the first one. and i think its bad to load it while driving. it almost sounds like something happened to the changer mechanism. cause the deck thinks like the first cd hasnt loaded and it wont let you put more in til it does.
Old Feb 11, 2007
k-man's Avatar
the problem is, as soon as i installed the deck, i tried to load a cd by pressing the "load" button, when i do that, the deck doesnt really do anything, it just says "busy". There are no CD's in the unit itself.
I beleive a reset may just do the trick, but i have no clue how to do it.
Old Feb 11, 2007
um have you tried putting in a cd? lol
Old Feb 11, 2007
k-man's Avatar
yess... a disc cannot be fed into the unit, the slot is physically blocked just in behind the flaps....
Old May 31, 2018
ReverbDaily's Avatar
ReverbDaily is an unknown quantity at this point
Re: Problem loading CD with SE/Reverb 6 disc unit
I know this threads 11 years old, but did you end up figuring out the issue? I'm having the same problem with the Reverb I just bought used
Old Aug 25, 2018
HondaHead786's Avatar
HondaHead786 is an unknown quantity at this point
Having exactly the same issue... anybody got any ideas?
mrtrinh
Jan 21, 2006 10:10 PM
vietstylez
27
Jun 5, 2004 11:16 PM
Snowman
Apr 9, 2003 02:33 PM
ZSKCivic01
Jan 5, 2002 12:15 AM
