plexiglass help
Old Dec 20, 2006
05civicFun's Avatar
05civicFun is an unknown quantity at this point
plexiglass help
i "stubled" across 1 1/2" thick plexiglass and we had the crazy idea of buildin a box with it, so im set on an idmax 12 and make a 1.3 cube box with it, we got the tools for it, but everyones stumped on the same thing.....how to get it to stick without screws or bolts
im going across every audio forum i can find with this question and am lookin for any ideas, were thinking of making it seamless or to use some sort of bracing thats color matched, but thats as far as we can go......
help.....
Old Dec 21, 2006
LudlamTheory's Avatar
i boogie for the raindrops
there is a special plexiglass adhesive, that in reality isnt an adhesive. it melts the seams and has them fuse to each other to create in essence one giant box shaped piece of plexi.
you will need http://www.rplastics.com/weldon4.html
you will also need good, very large clamps to set the plexi together
you will need to be able to make absolutely perfect flawless cuts
you also need something to buff the plexi edges before you bond them
you will also need a proper drill bit to make your speaker mounting holes, although i've found standard bits, with the drill set in reverse works fine
it's not easy to get it perfect with no scratches or imperfections
Old Jan 1, 2007
Scott Civic's Avatar
Racism sucks, just like your Mom...
Scott Civic is a glorious beacon of lightScott Civic is a glorious beacon of lightScott Civic is a glorious beacon of lightScott Civic is a glorious beacon of lightScott Civic is a glorious beacon of lightScott Civic is a glorious beacon of light
Maybe use a rag between the clamp and the plexiglass? May not help with the imperfections, but it's helped me before with scratches.
Regardless, heed this man's advice, 05civicFun. It'll be in your best interest.
Old Jan 3, 2007
whilechukwuzout's Avatar
From: Rochester, NY. Only women are allowed to stalk me tho.
whilechukwuzout is an unknown quantity at this point
Ive done lots of work with plexi glass. If it really is that thick, then trust me, use bolts. Cut the edges as well as straight as you possibly can, put some 3m double sided tape on the edge, and then drill a hole and tap it for a bolt. You will want to countersink the adjoined piece and put a nice neat hex-bolt in there. It looks very professional if you do it right. And it is not hard, it just takes time.
Old Jan 4, 2007
^Yeah, but that kind of defeats the purpose of doing it. One of the things he wanted to avoid were screws, so I'm not sure if that's really an option for him.
Day_Tripper
Mar 13, 2006 03:51 PM
Day_Tripper
Oct 22, 2005 05:39 PM
Day_Tripper
Mar 28, 2005 03:19 PM
