speaker q
Old Dec 16, 2006
klaudio's Avatar
klaudio is an unknown quantity at this point
speaker q
I have two 8's running off of a 300 watt kenwood amp. for some reason.. when it goes to thump, the whole thing turns off (amp and stereo) any insite into this? i dont know much about this kind of thing so sorry if its a lame q... just wanna get my **** workin right
Old Dec 17, 2006
hwt101's Avatar
hwt101 is an unknown quantity at this point
LMFOA, that **** used to happen to me i hated it. get a stronger battery (kinetics 1400 is good ) then get a 170amp alt ( www.4alterstart.com they make a nice one ) and finally upgrade your wires to 4 gauge.
Old Dec 17, 2006
ian01ex's Avatar
ian01ex is an unknown quantity at this point
Good advice but I would say upgrade the wires first, start out with a cheaper fix to see if that is the problem before you spend money of everything else.
Old Dec 17, 2006
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
2-channel amp?
amp model?
4 ohm drivers?
speaker brand and model or other specs?
what are you doing for crossovers?
what size power wire?
where did you go for your ground connection?
I want to make sure I understand correctly, everything is fine until a 'large' bass note is about to play and then things shut down. The amp and deck shut down from what I read, is that right? Do they come back on their own and if so after how long?
Surely this is an installation issue, the stock electrical system is up to the task of a 300 watt amp and two midbass drivers.
Old Dec 17, 2006
mr.rowdy's Avatar
mr.rowdy is an unknown quantity at this point
It usually is a safety device that is installed into the radio when you are pulling to many amp/power, mine did the same thing and i had to get a compasitor..
Old Dec 17, 2006
Srimmer2345's Avatar
New Member
Srimmer2345 is an unknown quantity at this point
you def do not need to drop that kinda cash into a batt and alt just to run a 300 watt kenwood that is probably only pushing 200 watts anyways lol maybe upgrade the wires....battery if its old but def dont need to drop 300-500 bucks into a new alt to run a 300 watt amp ha ha
Mad Dog Tannen
Oct 19, 2016 08:12 PM
UltraHDGames
Jun 8, 2016 05:16 PM
meicalnissyen
Sep 25, 2015 12:12 AM
Gsxtacy
Sep 12, 2015 01:09 AM
redcloud
Sep 7, 2015 01:45 PM
