system help?
Old Nov 29, 2006
01civicriderex's Avatar
The Random King of the Posts
01civicriderex is a glorious beacon of light01civicriderex is a glorious beacon of light01civicriderex is a glorious beacon of light01civicriderex is a glorious beacon of light01civicriderex is a glorious beacon of light
system help?
Ok i have had some ideas on getting a sub and amp in my new civic. But my battery is the size of a lawn mowers. Does anyone know if i could get a bigger battery or what? its a 01 honda civic ex coupe
Old Nov 29, 2006
rockinkcollins's Avatar
rockinkcollins is an unknown quantity at this point
I was running a 10 inch kicker L5 on 500 watts RMS no problems... until somebody stole it...
Old Nov 29, 2006
AequitasVeritas's Avatar
AequitasVeritas is an unknown quantity at this point
If you are truely worried about it you can get an Optima and/or a capacitor. Honestly I am running 2 amps off the factory battery with no problems.
Another thing you might consider doing is a higher amp rated alternator. reason for this is that the battery is only used to start the car where as the alternator supplies the power when the car is running.
Old Nov 29, 2006
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
My stock was ok with 800RMS.
Old Nov 29, 2006
thewood22style's Avatar
thewood22style is an unknown quantity at this point
I would probably recomend gettin a new battery depending on how big ur system is. I only had two audiobahn 10's with 400 rms each running with two visor monitors and I couldnt play my system for more than five minutes with the car running or it would die. Plus it will eventually put a lot of wear on the battery. I have an 01 ex coupe also. But thats just my opinion.
Old Nov 29, 2006
djdust12's Avatar
djdust12 is an unknown quantity at this point
Cheap fix is to get a capacitor - they do a fairly good job!
Old Nov 29, 2006
BRED civic's Avatar
BRED civic is an unknown quantity at this point
Get a True Yellow top Optima. Way better than average batter. As long as your not running over 1000 RMS nothing to worry about, also get a cap.
Old Nov 29, 2006
_unclejuice's Avatar
_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough_unclejuice is a jewel in the rough
with the car running? thats another issue. batteries arent used for anything once the car is running unless the altenator cant handle the load and drops below about 11 volts. the only time the altenator should bog down is at idle because the pulley isnt spinning fast enough to handle a massive load. bad voltage regulators wear batteries out. back to the topic at hand. ive got 2 10 inch JL's on 300 rms and i dont have any problems except lights dimming every once and a while. grab a cap and you should be fine. if that doesnt satisfy you, grab a high amp altenator but get ready to unload your wallet. a deep cycle battery is good if youre using your system without the car running a lot. they can take being drained and recharged a lot better than the stock battery.
Old Nov 29, 2006
05civicFun's Avatar
05civicFun is an unknown quantity at this point
i had a 15" L7 running 1600 in a competition setup so it prolly was more than that and it held fine
Old Nov 29, 2006
LudlamTheory's Avatar
i boogie for the raindrops
ran about 2300 rms on a stock battery fine.
bout to run about 3000 rms on an upgraded battery..
Old Nov 30, 2006
boxcarracer's Avatar
boxcarracer is a jewel in the roughboxcarracer is a jewel in the roughboxcarracer is a jewel in the rough
Cap, New Alternator, And Maybe Yellow Top....but Im Running Stock Battery Should Be Fine As Long As U Play The Subs While The Car Is On Or Else Ur Battery Will Die And Also Make Sure Ur 14.5 Or 14.6 When Ur Cars On Use A Voltmeter If It Is Ur 100% Fine With Tiny Battery
coumadin01
Electronics
25
Jul 25, 2019 04:19 PM
mjdiaz89
Jun 21, 2016 09:26 PM
carid
Nov 7, 2015 01:46 AM
