Acc Problem :(
Old Nov 15, 2006
hatE's Avatar
hatE is an unknown quantity at this point
Acc Problem :(
ok this problem is somethin that's driving me crazy.. my acc won't turn on wen i click my key over nor does the radio work.. i've checked all fuses (acc/radio.. acc/cigar etc) including the ones under the hood.. especially the back up at least 10 times now yet it still won't work..hazards/lights work so my battery is still good.. terminals in tact.. i've had a turbo timer connected but i've disconnected it but still no luck.. acc won't turn on and i can't even roll my windows back up ..i just can't figure out what else to do now.. i've come to a very bad standstill .. my car basically shut off while i was driving ..any help wud be greatly appreciated .. thx
Old Nov 15, 2006
Mr_Plenty's Avatar
Mr_Plenty is a jewel in the roughMr_Plenty is a jewel in the roughMr_Plenty is a jewel in the rough
damn..you got a serious problem...im sort of having the same issue with the acc but not as bad as your having only my radio doest work at times other times it just acts so weird that i have to hook it up to the constant(memory) current wire(which is yellow) i really cant help you on this one though you might have to take it to honda...
Old Nov 15, 2006
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
can you start your car? how was the turbo timer installed??
Old Nov 15, 2006
well the only things that work in acc mode are the radio and socket plug. most of the power functions like windows operate in the ON mode.
Old Nov 15, 2006
susuking's Avatar
susuking is on a distinguished road
i dun understand
Old Nov 15, 2006
hatE's Avatar
well basically wen i turn the key.. nothing happens.. so basically the car can't go into the "ON" position and i can't roll my windows up or down.. radio..cigar doesn't work.. and yeh i can't put it on the on position so i can't even start the car nor push start or anythin.. i was thinkin that maybe it cud be the ecu? ..iono..
Old Nov 16, 2006
CraigW's Avatar
Have you checked the large Amperage fuses in the under hood box ??
#19 & #20
Old Nov 16, 2006
#19 & #20
its either that or the installation of the turbo timer is causing a break in the ignition circuits
Old Nov 16, 2006
hatE's Avatar
whew.. ok it was the #20 fuse.. it was dirty so it was hard to really tell.. thx a lot guys for the feedbacks.. and yeh i think my turbo timer mite have shorted the fuse but its funy cuz i had it connected for about a year now . . but im glad it is working fine now .. thx again
Old Nov 16, 2006
ohsnapsjay08's Avatar
ohsnapsjay08 will become famous soon enough
i was just gonna suggest the fuse lol! GJ figuring it out yourself, thats how it usually turns out.
smmahan
Apr 15, 2015 08:17 PM
xHoteKx
Jan 8, 2002 09:15 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
Flatlander
Nov 16, 2001 05:38 PM
