lil help w/ viper 790
Old Sep 29, 2006
cravinspeed's Avatar
cravinspeed is an unknown quantity at this point
anyone remember how to program tach on the viper 790?
another dumb question... i turn off my car and the window switch lights and my check oil light flash. i noticed this problem after i added the led viper badge to my alarm. anyone know how i could fix this?
thanks in advance
Old Sep 29, 2006
christmaspie's Avatar
christmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of lightchristmaspie is a glorious beacon of light
Tach:
1. Start the car with the key.
2. Within 5 seconds, press and hold the programming button (valet button).
3. LED will light constant if tach signal is learned.
4. Release button.
The other ones are harder to immediately diagnose. What do you mean by window switch lights? It's not likely the alarm could trip an oil light if it was installed properly.
Old Sep 29, 2006
skipbarber's Avatar
^agreed. the only time i had this happen was when i had a back feed going to my reverse lights from my navigation system.
Old Sep 30, 2006
the window switch illumination blinks as well as the check oil light... its consistant with the led badge i installed (when the badge blinks "viper", the other lights blink also) if it is backfeeding how would i resolve it?
thanks for the help on the tach prog.
Old Sep 30, 2006
Hmmm, yeah backfeeding seems a likely culprit. Tough to just add a diode and hope for the best since the Viper light badge is a diode. Ok, a few more specific questions. Do you mean to say that your LED badge, check oil light, and window switch illumination all blink together when the alarm is armed? Are there issues when the alarm isn't armed? The only window switch light I know of is the little word AUTO on the left window switch, is that what you're referring to?
The first step might be to disconnect the LED badge and see what that does for you. Also, how did you hook the badge up, did you go right to the LED output on the brain of the unit (blue and red wires)? Or did you hook it up some other way. I would also recommend checking the ground for the entire alarm, make sure it's a solid ground (not loose, paint-free surface), preferably in the kick panel but other places are acceptable.
Old Sep 30, 2006
yes they all blink together. at first it was only the oil light because i had manual windows. then i installed power windows. and now the illumination on the switches blink also. the ground is right into the steel tube under the dash. and the badge is hooked up into the brain. although they all might be too close to the same grounding point??? i know the badge is grounded with the brain itself. i think this problem is above diode isolation.
Old Oct 1, 2006
Is the badge ground hooked up to the orange ground when armed of the alarm or is it just grounded? Where is the + lead of the badge hooked?
You could try separating your grounds or try adding a diode to the ground of the windows to see if that eliminates that (band of diode toward windows.) I've never put a diode on a ground, you'll get a voltage drop so hopefully it's not too bad. I personally think it should be possible to fix this without adding diodes but it's hard to say. This is most likely a grounding backfeed that could be eliminated by moving grounds, making sure none are loose, all grounds are paint-free, etc.
Geek-Squad-Man
Aug 20, 2009 06:47 AM
brent_G
Apr 18, 2007 03:25 PM
nunzio42
Jul 13, 2003 12:01 PM
BlueMeanie
Mar 21, 2002 05:45 PM
