remote start recommendation?
Anyone have one or know of a kit thats recommendation worthy?
I also have the stock Honda keyless entry system on my car already, is there any way I can just use that to start up the car?
don't trust the remote start/alarm combos on ebay. I bought one back in December, and ended up just dropping 400 extra dollars to get an autopage remote start/alarm installed.
Shouldn't matter where you buy...all that should matter is what you buy. Just be skeptical about e-bay.
As for remote starters...IDK, I've been looking forever too, can't find what I want from the brands I trust at a price I'm willing to pay!
Just think about it this way. You get what you pay for. I made the mistake of paying 150 for one on ebay, and when I finally found a shop that would install it, the whole system was inoperable. So I payed an extra 200 dollars to the shop for trying to install the broken system.
On another note. The majority of shops will not touch remote starts that are from somewhere besides their store. Bottom line is, just drop the extra cash and buy something reliable and is backed by the store that installs it.
i love my remote start.. best $150 (or whatever i dont remember its been like 3 years) i ever spent... i dont remember who its from.. i got it done at honda...
PWIT
how is it legal? all remote starts are illegal on 5spds, due to the fact that if its in gear it jumps. and i know my car if i leave it in gear it will jump then stall, then try again, and stall, and try again and stall. then it just stays off. but if i was like in a parking lot and remote start it would hit the car in front of me 3 times before it stopped.
I believe that the compustar system is able to detect whether you are in gear. I have a compustar system and i love it! Great range, lots of features, I only wish i had another $1000 to spend on solenoids to automate everything.
its legal because it is specially made for manual cars.... there's a 3 step process you have to follow if you want to use the carstarter... its very safe. Its got the longest range ive ever seen on any car alarm and starter.
P2WSS-AS (Alarm with Remote Start)
Coming Soon
Up to 6000 feet of Range
The next generation in Spread Spectrum technology is here! This system operates on 900MHz Spread Spectrum 50-Channel frequency changing technology. Firstech. LLC has spent thousands of hours perfecting the art of radio signal modulation and applying it to vehicle security and remote starts. With this reinvention and redesign of the Pro 2WSSR, we have taken security and convenience to the next level. The Pro 2WSSR has up to 1-mile to your vehicle and up to 2 miles from it!
(Includes 1 x Two-Way remote)
Pro Remote Features
- Two-way paging remote
- New multi-color LCD (liquid crystal display)
- CompuGlow backlight
- Vibration and audible notification
- Clock display with alarm
- Internal vehicle temperature display
- Parking meter timer
- Button lock
- Timer Start Mode
- Cold and hot starting with temperature
- Run-time indicator (extendable with
remote)
- Turbo Timer (extendable with remote)
- Secure auxiliary mode
- Shock sensor on/off through remote
- Passive mode on/off through remote
- Valet mode on/off through remote
- Uses standard AA 1.5 volt battery
Pro Alarm/Start Features
- Includes anti-grind and starter-kill relay
- Battery backup capable
- Time start set on remote by user
- External Siren (six-tone)
- Optional super bright blue LED
- Driver's priority unlock
- Ignition controlled door locks
- Includes dual stage shock sensor
- Secure valet switch
- Anti-Jacking mode
- Remote Paging System (can unlock vehicle via pin code)
- 2-auxillary outputs, expandable to 7 with Channel Expander
- 2-programmable inputs
- Selectable trunk release output
- Horn trigger output
- Diesel timer built-in
- Manual transmission compatible
Coming Soon
Pro Remote Features
- Button lock
- Timer Start Mode
remote)
- Anti-Jacking mode
The Peripheral NSS can make a remote starter work safely on a manual. You have to do a valet take over via remote before you get out of the car, then you get out and arm it. You can do one r/s until system is disarmed or alarm is set off.
GO LOW or GO HOME
I also got the 2wss-as alarm, it's great! The only problem is that the remote is very sensitive to damage. I'm guessing the remote was dropped too many times and I had to replace it. (there was no visible damage other than scratches). Same thing happened to a friend of mines but his also had a crack on the screen of the remote.
Civic2002lx
Oct 7, 2015 09:17 AM
MamaBear2015
May 3, 2015 02:17 PM
black2k1vtec
Dec 6, 2001 09:49 PM
loquito
Nov 12, 2001 07:24 PM
