Mystery audio problem
Old Mar 14, 2002
Gen7Civ's Avatar
Gen7Civ is an unknown quantity at this point
This problem just started about a week ago and had gotten very annoying. Almost every time I go to accelerate from stop or even just to speed up more my audio cuts out. Usually its everything but sometimes the sub is still going but thats it. I havent had time to check anything out yet except under the hood and that area looks fine. If anyone has any ideas Id appreciate hearing them because I have no idea whats going on.
I have a Blau Florida digiceiver, alpine r series coaxles all around, sony xlpod 40x4 with eq, kenwood 816 mono@200watts and a 10'' JL in a powerwedge box.
Old Mar 14, 2002
PlatnumBomb's Avatar
PlatnumBomb is an unknown quantity at this point
is the amp only hooked to the sub???
or is it to the other speakers??? I used to have my inside cut out cause my remote line kept coming lose during turns...had to tighten it down...Check all your wires is my suggestion...Then from there you know its something thats more internal hardware not just hookin everything up right!!!
Old Mar 14, 2002
Subrage's Avatar
Subrage is an unknown quantity at this point
sounds like a grounding problem
Old Mar 15, 2002
Gen7Civ's Avatar
The sub is hooked up to the Kenwood and the 4 coaxles are powered by the Sony Xplod. Thanks, I'll have to check all the connections and grounds.
Old Mar 15, 2002
Ed's Avatar
Ed
yeah, it sounds like it' somewere with the sony amp, try the wires there and try check if the power light is still on when it goes out.
-Ed
Old Mar 16, 2002
Gen7Civ's Avatar
Found the problem, which I didnt even see the first time...the 12v wire running from the sony amp into the Stinger fuse box was loose but still making some contact. Re-tightened it and all is good.
jtdunn4life
Oct 27, 2015 03:33 AM
Optimus34
May 25, 2015 11:52 PM
djaber
Jan 4, 2002 06:23 PM
JDog2001CivicEX
Nov 2, 2001 02:27 PM
