Keyless with key in ignition?? Possible???
Old Aug 16, 2006
redrocket600's Avatar
redrocket600 has a spectacular aura aboutredrocket600 has a spectacular aura aboutredrocket600 has a spectacular aura about
I would REALLY like to be able to lock and unlock my car with the keyless while the car is running....I sappose this is a dead end question but does any one know how to accomplish this??
Preferably without buying remote start....
Old Aug 16, 2006
BlackKnight008's Avatar
420 Member
BlackKnight008 has a spectacular aura aboutBlackKnight008 has a spectacular aura aboutBlackKnight008 has a spectacular aura about
uh remote start...
Old Aug 19, 2006
WhiteRabbit's Avatar
disconnect the ACC lead to the brain after the keyless unit is programmed.
that should "force" keyless to always work. even on the freeway at 60 mph.
Old Aug 25, 2006
Where is the box located???
Old Aug 25, 2006
to my knowledge in the drivers side underdash. I didnt realize you were talking about the factory keyless. I haven't seen a pinout for that system, So I dont know if its that simple. But if it uses ACC as a "turn off" lead so to speak, you can definitely simply cut it.
try to find a pinout.
Old Aug 26, 2006
Would mine be in the same spot as http://www.handaaccessories.com/civic/05keyless.pdf? How would I find which wire is the acc. wire? Voltmeter/power tester?
Old Sep 14, 2006
BUMP
Nobody knows anything a-boot this? There's gotta be someone who installed factroy security system after they bought their car!
Old Sep 14, 2006
I'd try what this guy suggested. you can use a multimeter to determine if you do have ACC on the wireharness if you can not find a pinout online.
Old Sep 15, 2006
10 4! Humm...I find it weird when people quote themselves!
henrytn
Aug 11, 2015 10:01 PM
mr_cb7
Aug 11, 2015 09:20 PM
liamfry91
Aug 9, 2015 07:54 AM
sam31444
ECU Fried
Jul 20, 2015 08:31 AM
cukaracha
Jul 17, 2015 05:48 PM
